Liked 586 Times in 162 Posts
If the -.95 new Mineshaft rule had been in effect still then Pomona would NOT have gone mineshaft. Wonder how many would have proceeded to run better than -1.00 would have held back had the old new rule stayed in effect?
Liked 478 Times in 91 Posts
Lets just do away with mineshaft period....
This will allow a little more room to run your stuff out...while also appeasing those in favor of the AHFS.
Austin Williams 3 SG 464Q STK SC |
Liked 309 Times in 88 Posts
Is the end of year average still 85 under for HP consideration?
Liked 239 Times in 90 Posts
I just appreciate the bottom half of the field stepping up and making it mineshaft. I am on my 3rd set of exhaust valves in as many passes and was not needing any more weight put in my car because it is already slow. And when you have the 2 fastest in the country with my combo over there and one of them trying to sell his and prove how fast it is, I wasn't happy...at all.
Liked 10,713 Times in 2,230 Posts
May want to check P/V clearance at split overlap or improve angle of piston to valve.
Liked 223 Times in 73 Posts
As I type this there has been 2 runs that are not considered mineshaft from the Div 2 race.
There are 19 runs of one second under that are mineshaft runs. How is the AHFS suppose to work when this many runs get excluded? This is only with the first round of the winternational,2nd round should have some more runs of one second under. There is a AA/SA heads up run coming this morning also.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#7 | |
Liked 229 Times in 99 Posts
Floyd Staggs 787 SST |
#8 | |
Liked 2,354 Times in 554 Posts
With the mineshaft rule at .950, I doubt you would see many fast runs at all.
Daren Poole-Adams NHRA Stock/SS 2007 |
