Liked 48 Times in 13 Posts
In SS can you shift on rpm or time?
Liked 165 Times in 51 Posts
What ever turns your crank on that one!*
Glen DeMenge 1969 Camaro Stock Eliminator |
Liked 4 Times in 3 Posts
I thought only RPM was allowed?
Using "the transbrake release" to start a timed event seems defiant of current rules in Super Stock? |
Liked 1,930 Times in 580 Posts
Pretty sure the only things allowed to be hooked to the trans brake circuit is the brake solenoid and the rev limiter. They even frown on the replay tach connected to the brake circuit
Mike Pearson 2485 SS |
Liked 5,121 Times in 1,952 Posts
You can shift by time if you use your wristwatch..
Liked 2,486 Times in 697 Posts
We always use RPM on our SS cars.
We do not wear watches.
Liked 299 Times in 48 Posts
Hmmm, I don't see any options for using MSD power grid in the rule book? Is this located somewhere else?
Liked 36 Times in 26 Posts
Need to look for accepted products list, probably on nhraracer.com
#10 | |
https://www.nhraracer.com/Files/Tech...edProducts.pdf Last edited by Mike Mans; 04-05-2022 at 10:09 PM. Reason: edit link |
