Old 04-28-2022, 11:28 AM   #1
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Default Stick Bellhousing - To cut or not to cut
Have you stick guys made an access panel for clutch adjustment? What have you done. Thanks
427FE is offline   Reply With Quote
Old 04-28-2022, 08:43 PM   #2
Chevy55
Banned
Liked 179 Times in 89 Posts
Default Re: Stick Bellhousing - To cut or not to cut
You can drill a 1in hole in the face of the bell to access the adjusters but you will have to slide the tranny back to adjust the pressure plate.
I believe the only way to have a removable panel will be to buy a bell with the removable panel that is SFI certified.
Chevy55 is offline   Reply With Quote
Old 04-28-2022, 09:21 PM   #3
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
I sent mine to the Manufacturer for a window, Quicktime in my case. Chevy 55 is right it has to be re-certified after any modifications are performed.
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 04-30-2022, 09:04 PM   #4
T Ames
T Ames's Avatar
Liked 125 Times in 33 Posts
Agree with the previous responses, and would add that Browell makes an excellent bellhousing. They will customize to meet customers' needs including SFI compliant window to ease counterweight adjustment and hole through the back for quick adjuster changes.
T Ames is offline   Reply With Quote
Old 04-30-2022, 10:44 PM   #5
Randy Wells
Liked 1,144 Times in 354 Posts
I wanted to buy a Browell, 12 months later still waiting. I bought McCloud, a few hundred dollars cheaper, lighter and adjustable friendly for clutch and air gap.
Randy Wells is offline   Reply With Quote
Old 05-01-2022, 10:14 AM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
The Browell bellhousing was probably one of the best purchases I have made. As Mr. Ames pointed out, you can have the window clocked anywhere. The hole for air gap measurement they will drill and tap it for a plug. The other added benefit, alignment was spot on with 2 different engines. You get what you pay for.
427FE,
If you are wanting to modify the bellhousing yourself, its been done. Others will tell you "Tech has never looked at my bellhousing certification date so have at it with modifications". That is up to you. For those with bellhousings without a window, its not uncommon that they drill a hole so a long allen socket will reach the adjuster. CW is a different can of worms. I fabricated offset wrenches and would put duct tape on the wrench to capture the hardware and reach through the fork window. It was a fishing expedition when I dropped aluminum nuts or bolts!
There are pictures and how people with fabrication skills added a window to their bellhousings on the internet.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 05-03-2022, 10:19 AM   #7
427FE
427FE's Avatar
I wanted to buy a browell, but they couldn't accommodate a 184 tooth flywheel, didnt want to go down the custom starter route. Thanks for replies.
Old 05-04-2022, 03:42 PM   #8
Dave Casey
Liked 804 Times in 168 Posts
I had a non window Quiktyme and it needed to be re certed , they recerted it and put a window in it very reasonably. They also told me that the window bells for stock are now a 5 year recert, previously a 2 year
Dave Casey 1330 STK
Old 05-04-2022, 09:10 PM   #9
Stephen & Horace Johnson
Liked 165 Times in 54 Posts
When was this, I had mine recertified and was told 2 yrs since the window is in it?
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 05-05-2022, 07:02 PM   #10
427FE
427FE's Avatar
Also quicktime wanted $500 extra for the window
