Liked 53 Times in 38 Posts
To the Mopar group, what angle do you weld the perch (on housing) when using the Calvert setup and mono spring? Same as stock? A-Body car
Liked 5,125 Times in 1,953 Posts
Why not ask Calvert?
Rather ask Mopar guys
Liked 2,486 Times in 697 Posts
We run 1 to no more than 2 degrees down.
If you miss it can be corrected with wedges from most spring shops. Try to not get housing real hot.
Thanks, some said 5 or 3 down, I like 1 or 2 idea
With the old SS Springs or Tri City Super Launchers
3 to 4 would be correct but not for the Calverts
Liked 253 Times in 95 Posts
I switched from SS springs to caltracs and didn’t move the perches. It’s the original housing with the perches in the factory spot. Car hooks all the time. Just check the housing alignment, my car was 3/4” different from one side to the other.
George Mirza D/SA 1236 ‘71 Duster 340 |
Liked 10,734 Times in 2,233 Posts
The spring perch can be a real challenge. The housing has to be straight with the body. It needs to be zero toe in or out. Camber has to be zero or the tires won’t be 90* to the track. Everything may be just perfect until you weld on it. Then everything changes. A thick tube housing will still move as in a Dana 60 but not as much as an 8 3/4. The first one I did the axels would not go in without a hammer. The fun part was getting it straight again.
One to two degrees down |
Liked 348 Times in 152 Posts
Weld on the opposite side of the tube and it will pull it back. Ugly, but it works. Or, get somebody with a jig to put new ends on it after you weld the perches on.
Phil Molski PMR Performance S/C 1623 |
All good advice so far, racers know their stuff.
