Old 03-08-2023, 02:16 PM   #1
Weekend Racer
Default roller lifter
Hello! This is a sbc . New Jesel DLC coated pro-tie bar roller lifter .903 ,in Dart shp pro block with 55mm cam . I have an issue with the lifter .It Looks like it blocks the oil gallery off at Max lift .Has anyone noticed the same problem?
Weekend Racer is offline   Reply With Quote
Old 03-09-2023, 10:39 PM   #2
mike britt
Liked 66 Times in 31 Posts
Default Re: roller lifter
Given how much time the lifter spends at max lift how would that cause any issues? Less oil to the top is a good thing.
mike britt is offline   Reply With Quote
Old 03-10-2023, 10:04 AM   #3
Bob F
Liked 16 Times in 11 Posts
Base circle correct?
Bob F is online now   Reply With Quote
Old 03-10-2023, 10:49 AM   #4
Weekend Racer
at cam base circle lifter oil band is well exposed to the oil gallery.
at .050 from max.lift the lifter oil band is no more exposed to the oil gallery. Thank!
Old 03-10-2023, 02:06 PM   #5
Dirk Olson
Liked 172 Times in 46 Posts
A little line with a die grinder on the lifter oil hole will allow oil to flow, will not need much.
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 03-11-2023, 05:39 PM   #6
Weekend Racer
These lifters had the lower edge of the oil band sitting higher than a “normal” lifter, and when the lifter was near the very top of the lobe, the band was no longer exposed to the gallery, and effectively shuts off the oil supply from that point forward. Also if I have to use a die grinder to make this lifter work,I understand this are not the lifter one I need !
There are few cheaper one that have the oil band well located. Thank you,
Old 03-14-2023, 08:40 AM   #7
SGSST109E
Liked 126 Times in 61 Posts
Did you call Jesel?
SGSST109E is offline   Reply With Quote
Old 03-14-2023, 05:04 PM   #8
Weekend Racer
Originally Posted by SGSST109E View Post
Did you call Jesel?
I have sent an email with some pics ,still waiting !
Old 03-14-2023, 08:05 PM   #9
kirk
Liked 5 Times in 4 Posts
I have seen a few customers had the shop here mill a groove on each lifter. It doesn't need much, seems like it was only 3 thousands deep. Also a issue with Comp lifters and SBC dart block. If you don't groove them, keep a eye on the amount of oil under your valve covers............
kirk is offline   Reply With Quote
Old 03-15-2023, 09:12 PM   #10
Weekend Racer
Question Re: roller lifter
Did you call Jesel?
Yes ! Here the answer I got from Jesel:``I would mill a flat on the body just to be safe, especially if you are using the lifter band to feed bore to bore ``
