Old 03-14-2023, 03:15 PM   #11
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
Default Re: Factory Stock Showdown
How loose did he get in the semi ?
Jake Biermann
Old 03-14-2023, 07:57 PM   #12
kirk
Liked 5 Times in 4 Posts
These cars are in fact a small tire radial car....Just a 30x9 instead of 28. I see some of the class were quicker than Welch's, all increments until the 660, then his car really started moving.
kirk is offline   Reply With Quote
Old 03-15-2023, 02:56 PM   #13
wdrevojr38
wdrevojr38's Avatar
Liked 51 Times in 9 Posts
I was wondering about the rake on Joe’s car but when I saw how loose he got down track in the semifinals one has to wonder. With the MPH he’s running a “parity adjustment”‘might be coming.
The mph that car is running is a monster number for that class which represents a lot of horsepower……..hmmm! That ‘nose down’ attitude’ for that car keeps frontal air from getting up in the engine compartment which would help it’s mph number a little bit. That car’s ‘nose down’ effect is similar to the optional front air dam (with rear spoiler) available on the ‘67 - ‘69 Camaros which also kept frontal air from doing the same thing.
wdrevojr38 is offline   Reply With Quote
Old 03-15-2023, 07:39 PM   #14
jimmyparker
Liked 309 Times in 88 Posts
I understand the drag radial group checks the heat on the u-joints after every run and replaces every three or four runs, evidently the severe chassis separation is causing drive shaft angles to be out enough to warrant this.
jimmyparker is offline   Reply With Quote
Old 03-15-2023, 08:18 PM   #15
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Originally Posted by Bent Valve View Post
If I recall Welsh got bounced a few years ago for a rear suspension issue. Maybe he has figured out some new settings to get the car to leave like a small tire no prep car. Sure looks like it.
He did get disqualified @ Indy 2018 after he ran the first 7 second run, his DQ had to do with adjustable lower rear control arms which weren't allowed, the rod ends and lock nuts were welded, and had competed @ several earlier NHRA events. Welch's car spends lots of time at Mike Moran's shop in Michigan.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
