Old 03-24-2023, 12:22 PM   #31
Paradigm Shift
Liked 80 Times in 29 Posts
Default Re: I need to apologize!!
It was clear to me from the get go that .70 under runs are gold and you need as many of them under your belt as you can get.
That's an interesting suggestion. What was the reasoning behind it?
Paradigm Shift is offline   Reply With Quote
Old 03-24-2023, 12:36 PM   #32
GUMP
Liked 2,354 Times in 554 Posts
For someone with so much to say, you sure are out of touch...
Daren Poole-Adams
NHRA Stock/SS 2007
Old 03-24-2023, 12:41 PM   #33
Paradigm Shift
You may be correct.
It's the lack of due diligence that is at the foundation of my character flaws.
At the risk of incensing some, I'll ask again.
Old 03-24-2023, 01:32 PM   #34
Mike Pearson
Mike Pearson's Avatar
Liked 1,926 Times in 579 Posts
The way I read the review process is if there are 2 runs more than 1 second under the index for a particular combo and platform then an automatic review will happen. If the class average is more than .85 under at the time of the review the combo will receive a HP increase based on the fastest run by that combination. If the class average is less than .85 under then index no HP increase happens. So if you made 2 runs faster than one second under this year you will automatically get a review to check the class average.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 03-24-2023, 01:52 PM   #35
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Couple of questions, is Indy going to keep AHFS in this year? If so it would almost certainly get a trigger there at some point. There is plenty of season left though so it's way early to predict who or how many will get a HP increase.
Is the 1969 350/300HP combo that much worse and what parts are different than the 255 version? Point being if it's an intake manifold change and that is not as favorable maybe you can run that combo at the faster races typically,
I don't have a horse in that race anyway
Old 03-24-2023, 03:00 PM   #36
Doug Hoven
Liked 855 Times in 164 Posts
The 350/300hp uses a different cylinder head. It uses the earlier style head (462, 186, 041 etc.). I'll have a better understanding of 255 vs 300hp after I get my 70 300hp motor together and in the car, hopefully within the upcoming months. One thing I can't seem to understand, as a 69, you can run the 255hp, 300hp, or 70 300hp intake on the car, but as a 70, you're only allowed the 70 intake. There's still a decent number of racers running the 67-68 295hp combo, which is the same as a 300hp except for the intake, but no one seems to be going as fast as the 255hp cars.
1189 F/SA
Defunzalo Racing Enterprises
Old 03-24-2023, 03:14 PM   #37
GUMP
You may be correct.
If you have five .700 runs and you make a 1.20 run you will not get HP. The more .700 runs you bank, the more times you can let it hang out. Obviously, that only applies if everyone running your combination follows the same plan....
Daren Poole-Adams
NHRA Stock/SS 2007
Old 03-24-2023, 04:42 PM   #38
Paul Wong
Liked 419 Times in 85 Posts
Daren laid out the answer spot on. If you bank your average at .70 under, when you go 1.15 it won’t bite you. If you plan on class racing or winning a heads up in the eliminator and don’t want to move classes next year, then they have laid out how to play the game with their bat, ball, glove and field.
Paul Wong is offline   Reply With Quote
Old 03-24-2023, 04:53 PM   #39
GUMP
Just keep in mind that you need enough .700 runs to cover each fast run that you make...
Daren Poole-Adams
NHRA Stock/SS 2007
Old 03-24-2023, 05:05 PM   #40
Bob Sherwood
Liked 388 Times in 60 Posts
Good post Daren -- This is the problem with this whole program . Someone has 1or 2 triggers in March already , and they will have to throttle-stop their car the rest of the year, and hope everybody does the same. Doesn't look like a good way to race to me !!! I have no interest to run my car that way.
Bob Sherwood is offline   Reply With Quote
