Old 07-02-2024, 01:13 PM   #1
Glshire85
Default Lifters
Okay, for Stock Eliminator..what seems to be the Go-To lifter of choice for us forced to use a flat tappet? Thank you in advance
Glshire85 is offline   Reply With Quote
Old 07-02-2024, 01:22 PM   #2
jcw31
Liked 6 Times in 6 Posts
Default Re: Lifters
Ohhhhh boy !
jcw31 is offline   Reply With Quote
Old 07-02-2024, 02:13 PM   #3
Billy Hampton
Liked 54 Times in 19 Posts
Default Re: Lifters
Guys,
I know we have beat this subject to death but let me add my perspective to this.
There is a solution and is proven to work as demonstrated by the results over the years.
My dads (Professor Rock) ceramic based coating on lifters (and cams) has been used for years and is an effective solution to this. He can supply Topline Johnson Hy-lift lightweight solid lifters (Made in USA) coated with a ceramic based low-friction and wear reducing coating.
Want a recommendation? Ask Chris at Bullit about him and the coating and how effective it is.
See more info at his FB page www.facebook.com/rocketmanraceceramics
Thanks, just offering the solution.
Billy/Liam Hampton
Billy Hampton is offline   Reply With Quote
Old 07-02-2024, 02:15 PM   #4
BRETV
Liked 776 Times in 199 Posts
Default Re: Lifters
Deleted
Bret Velde
2003 I/SA
BRETV is online now   Reply With Quote
Old 07-02-2024, 04:49 PM   #5
Doug Hoven
Liked 867 Times in 165 Posts
Default Re: Lifters
If you?re not using a billet cam, and don?t want to break the bank for a set of lifters, I have had good luck with Clay Smith lifters. They are made in the USA, are reasonably priced (about $250 per set), and have broken in very nicely for me for the 3 sets I?ve used so far. At the end of the season the cam lobes and lifters still look like new.
1189 F/SA
Defunzalo Racing Enterprises
Old 07-02-2024, 09:20 PM   #6
James Perrone
Liked 1,829 Times in 427 Posts
Default Re: Lifters
Trend tool steel
james perrone 1290 STK
Old 07-03-2024, 10:59 AM   #7
goinbroke2
Liked 393 Times in 153 Posts
Default Re: Lifters
Just broke in a flat tappet (comp) cam with a set of off the shelf comp lifters. Slathered on the EOS (gm engine oil supplement) 50# seat pressure and 35minutes at 2200-2500. Worried they might not break in with that low of pressure but they did.
Oh, 120 or something like that over the nose.
Jim Miller
103 U/SA
Old 07-03-2024, 02:48 PM   #8
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default Re: Lifters
Jim it?s a little more of a problem for those of us that need 200-250 seat pressure to control these things, they won?t even control the valves at break in rpm with pressure that low.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 07-04-2024, 01:48 PM   #9
Billy Hampton
Default Re: Lifters
Originally Posted by James Perrone View Post
Trend tool steel
Steel cam & Lifters- Cam manufacturer recommends coating of some kind on one or both.
Billy/Liam Hampton
