Old 11-21-2008, 11:37 PM   #1
Darrin Christen
Darrin Christen's Avatar
Default 66-67 chevyII
Does anyone make a good double adjustable shock for the front of a 66 chevy II that will fit the stock mounts? I just purchased a pair of Afco's that don't fit. What are the super stock guys using for these cars, and do you have to run the factory spring, or can you convert it to a coil over set up with the stock upper a-arm? Any help would be appreciated!
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 11-22-2008, 08:30 AM   #2
james schaechter
Liked 1,428 Times in 296 Posts
Default Re: 66-67 chevyII
You cannot do a coilover converstion, but don't pitch your AFCOs yet.
Call this guy. He makes a mount for the bottom of the shock.
http://www.matukasmotorsports.com/index.html
James Schaechter 3163 STK
james schaechter is online now   Reply With Quote
Old 11-22-2008, 10:48 AM   #3
Darrin Christen
Thanks James, I'll give him a call. The problem with the afco is the bottom adjuster on the shock makes the overall diameter of the shock to large to fit inside of the factory spring. What shocks do you run on the front of your car? Thanks
Old 11-22-2008, 08:20 PM   #4
chassis1
Liked 9 Times in 3 Posts
send me an email address and I can tell you what Afco number it is for the part that will make it bolt on without a problem...
http://proheadersystems.com/gallery/...ns+duece&id=53
info@proheadersystems.com
chassis1 is offline   Reply With Quote
Old 11-24-2008, 08:00 PM   #5
chassis1
I found the part # and its a part you can get from Afco. Email me and I will send it over. Also I will explain how we got the car to sit this nice and also work as well....
402.438.0430
Chassis1
Old 12-01-2008, 10:35 AM   #6
Tilley2007
Guest
Posts: n/a
What brand of front coil springs are you using?
Old 12-01-2008, 02:26 PM   #7
Darrin Christen
Originally Posted by tilley2007 View Post
what brand of front coil springs are you using?
moroso trick springs
