Liked 138 Times in 22 Posts
just put one on 69 nova drilled holes in master cyl worked great drilled one size bigger .
BILLY HARPER |
Liked 46 Times in 29 Posts
on a friends 69 camaro, I used a willwood 7/8 bore, disc front drum rear.bolted right up where power booster did no mods but, I need to make a spacer as the pushrod which is attached to master was too long. works real well.
Liked 166 Times in 71 Posts
Had this problem on a cutlass last year with the 1"master. I knocked the studs out of the pedal bracket, ovaled the holes with the die grinder, and used some grade 8 bolts. Didn't modify the master at all. Works great, no problems.
Liked 18 Times in 9 Posts
I put the Strange master cyl on my 69 Camaro. Slotted the holes, added flat washers to increase clamping force and still good 15 years later.
Jim Grande SS/D 5007 |
Liked 60 Times in 12 Posts
What about the lines ? Are they a pretty good match ?
2894 STK |
Liked 1,958 Times in 593 Posts
I did the same as Jim Grande with the slots and washers. works great. Kenny my master cylinder had metric threads in it. I had to match up some new fittings and reflare the lines. Pretty easy install.
Mike Pearson 2485 SS |
I drilled the holes on my master cyl just large enough to slide over the studs and used washers behind the nuts,this way it would still center itself in the bore.works fine! Mine is a 71 pontiac ventura,same car.good luck
scott fifield |
