Old 03-16-2009, 05:32 PM   #4
5798camaro
Default Re: Battery Question
Originally Posted by Bill Harris View Post
Don't kid yourself about how much the water pump and fan draw. If you are like most, you run your water pump and fan for a while after getting back from a run. If you don't put it on a charger between runs those two items alone can really draw down a battery, especially a single battery. Do you run your pump and fan at 16V too or do you have something that drops the voltage to 12V for those item?
You should check out shoguns web site they have some good products and are pretty cool to work with I have one in my car the nice thing about it is the faster your motor turns the more power it puts back in your battery. not sure what they have for 16 volt stuff though
5798camaro is offline   Reply With Quote
