Old 04-10-2009, 07:07 PM   #1
csjta
Default Re: T-400 fluid?
Dexron 6, good stuff, but it ain't cheap
csjta is offline   Reply With Quote
Old 04-10-2009, 08:57 PM   #2
njk53
Be careful using Dex VI. Dex VI is not compatable with the material that is used to manufacture some seals.
Nelson Kowal
Stock 345
Old 04-10-2009, 09:09 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
All GM Dextron fluids at back compatible. The newer fluids, were developed as an improvement on past fluids, and are more stabile, and maintain their viscosity better, cold to hot. Part of the reason for the new Dex 6 fluid is to have a 100,000 mile service life in cars running normal conditions. Heavy duty driving still needs fluid swaps as recommended in the owners manual.
Old 04-11-2009, 11:55 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Mopar ATF+4 also performs very well in race applications. .........holds up very well in high heatand has excelent anti foaming properties.....Even available at Walmart! ....I've been using it for about 5 years in both my stocker,a TH400,without a cooler, and my SG car, which runs in high gear all the way down the track. ......No wear problems,or clutch issues. .....Tom
