#11 |
Liked 119 Times in 40 Posts
[quote=Joe Marcinowski;111879]Try IHRA Pure Stock.
Easier and cheaper than Stock, and you do not have to molest the car. A great place to learn, then step up when your ready. Good Luck, Joe[/ Last edited by Frito; 04-01-2009 at 05:30 PM. Reason: .. |
#12 |
Liked 5 Times in 3 Posts
I agree on the prue stock deal if you live close to an IHRA track. That's the way I got dad started the we built him a "real" stocker. As far as pure stock goes the 87-93 5.0 mustangs are EASY!
#13 | |
Still working on it. Really don't want to run a late model mustang but i can see were it would be easy. Really need to sit down and understand the rules, we have a pro am coming to Pinevalley in June I think. My set up the Bracket car for Super street and see what its all about? Thanks for the info Phillip |
#14 |
Just saw this, not a bad start.
http://www.aatwracing.com/olds.htm
Jason M Silver NHRA Stock Eliminator - 1278 88 Oldsmobile Cutlass 307/213 |
#15 | |
Banned
Liked 235 Times in 110 Posts
#16 |
Thanks for all the input, Sorry no reply been busy traveling,
Found a 73 duster, 1 owner very clean has been sitting up for a while, still has the build sheet behind the seat. It has a slant 6 and a factory 4 speed, been looking at the car for a while and final caught someone home. he is willing to part with it though. Not really a mopar fan, have always built chevy's and a few fords, but wonder if this car will fit a class that is less demanding? like the body style, don't know if the 6 would be worth the trouble? Like to olds that's not a bad price, i sent out some e-mails out about the late model nova, no replys yet, seems like it ran 1.5 over the number, Anyway still working on it, sounds like the pure-stock may be the way to go. May go with the 68 camaro anyway, at least its sitting in the shop.. Thanks again. Phillip |
#17 |
The Duster would be a good choice for pure stock run as a 74 with the 360/904. The engine rules are as NHRA stock eliminator was in the early 80's before it got out of hand. You can take an additional 10 hp off as you would be using the factory 904 trans. Also, the cam duration specs are quite generous, and the combo will easily run way under the index.
#18 | |
As stated before The rules are a little hard to understand, what is needed to change year models, just state it to be a 74 or is there badges etc.. to be changed? Thanks Phillip |
#19 |
Liked 251 Times in 125 Posts
Go hang out at some races. The more the better. Ask questions. See what it's really about before jumping in. Have you read some of the threads on here?
#20 |
Making the races, was in houston couple weeks ago. spent most of my time in the sportsman pits, yes have read some of the quotes still learning though. seems like there is a lot of info to swallow. getting some great info though.
