Liked 70 Times in 29 Posts
Does the AODE have a lock-up converter? I used to run the original AOD in my car. It had the two piece input shaft that actually locked up 1 to 1 like a stick car in drive. It really killed the car on the 2-3 shift though.
If you switch to a C-4, make sure you get a full roller/race version with a low gear set. I went from the AOD to a street/strip C4 with very little difference. Same brand of converter (PTC). More top end rpm and I believe about 2 mph. Do you know anyone you could borrow a set of 28" tires from? I would try them too.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 5 Times in 3 Posts
Add 10 degrees to you cam #'s put a C4 in it with 2.91 low gear & call ATI for a converter!
I can't comment on the transmission issue....however, are you still using a stock 94/95 EEC? Older EEC's do not pull timing on the shift.
Liked 11 Times in 4 Posts
charlie we have the same car so i can give you some numbers tomm. i go to the chassis dyno then to the track for the first time i will pm you with my info i have a bullet cam like rory said.
larry dowty 6388 SS |
Chris
I am using a non lock up after convertor in that AODE Swandog I have programed my Tweecer to eliminate the retard when shifting. Larry I will be looking foward to that PM. Best of luck to you. Charlie |
