#1 | |
Liked 4 Times in 4 Posts
I don't remember either but those rear ends went into a lot of gassers at the time. There are probably gear sets floating around at swap meets. Jim |
Liked 1,836 Times in 417 Posts
Until recently, Strange, and even Mark Williams had stuff for the Olds/Pontiac rear end. However, if you are going to the trouble to change, change to the 12 bolt Chevy. I want to see that car go fast and go rounds. You've suffered enough, for a long time, to make it work, just get a 12 bolt in it and enjoy the car. You've earned it.
Alan Roehrich 212A G/S |
#3 | |
Liked 705 Times in 219 Posts
Pretty sure the 'late' Olds/Pontiac's are 9 3/8ths. Not too many ratio's to choose from.
Sure wish you were going to be at Spokane, Aubrey. I'd really like to see your '62 in person. Any chance of that? |
Liked 333 Times in 180 Posts
pontiac/olds dimensions 1.875 pinion dia----9.3 ring diam Comp387
I'll have the current rear end re-geared this week, Ken, and the car will be ready to go. No money for another big trip though. Next outing will be Edmonton, for the IHRA Rocky Mountain Nationals. Same exact weight... but dropping into D Stock ( because of a somewhat soft HP factor ).
As for the final solution for the rear end, yes, I would be more inclined to use an old Pontiac/Olds rear... but as has been pointed out, I don't think it fits within the way the rules are written. So, for this season, I'll make sure I have a couple sets of 5.13's on hand. However, I have come up with a bit of an "off the wall" idea ( I know, the car is already off the wall ) as a possible solution, which I will attempt to to put into motion this winter. In the mean time, it's so off the wall, that I dare not mention it !
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
#7 | |
Banned
Liked 235 Times in 110 Posts
