#31 |
Banned
Liked 235 Times in 110 Posts
It can be done....I did it all the time. I checked the winner of the quick 32 S/S at the US Class Nationals several years ago and my measurement was "Dead on" the manufacurer spec. and matched the engine guide in the car at a 45 degree angle while leaning over the fender. If I remember correctly it was Randy Manns car. It was an Olds engine in a Camaro or Firebird (cant remember which) SS/GT car. It even surprised him.
#32 |
RJ you said your burette checked the same as NHRA Tech's burette. The NHRA Tech's burrette's (2) I checked from our Division did not check against each other as I said there was a .8 cc differance.
I tried to call you when I was in Pipe Creek, I have the wrong phone number. Jerry |
#33 |
Banned
The given tolerance for a burette is 1%. On a 100 C.C burette that is 1.0 (one point zero) C.C.s. Reason alone to allow some wiggle room when milling your heads. Not only the burette is involved but the medium usuallly used is alcahol and is tempature sensitive. A hot cyl. head will not check the same as a head at room temp. The alcahol will expand when the head is hot and give you a smaller reading. Some go so far as putting the head into a cooler full of ice to bring down the temp of the head. 1/2 or even a full C.C over the spec. will not slow down the car. The engine will never know it.
#34 | |
Liked 31 Times in 12 Posts
Also keep in mind some features are more difficult to measure than others. The most difficult are visual attributes or specifications. One persons course finish is another’s fine. A color (one of the most difficult) may look light blue to one person and medium blue to another. The budget for the measuring system plays a big role. Like anything else, you get what you pay for. Last edited by Pete Beau; 09-05-2009 at 08:10 AM. |
#35 |
Liked 308 Times in 103 Posts
I was reading post and going to make basically same statement as you Terry.It does'nt matter what your
burett or mic's or caliper shows the tech man goes by their tools reading it's our responsibilty to leave room in our measurements for difference in gauges,just like lbs per cubic inch classes it's your responsibility to claim correct cubic inches.I had customer truck pulling406'' limit so everyone built400sbc 30 over he got pumped 406.7 would'nt pass so I had to destroked cranks to 3.735 stroke deck block.007 rebalance actaully ran better then because crank had stroke&index equalized then. I heard of some Dodges that got bounced at Indy several years ago few minutes later truck owner supposedly came up on golf cart w/ the updated specs that had been faxed to him from mopar so they were legal.Has anyone else heard that story before? Mike Taylor 3601 |
#36 | |
Chad Rhodes 2113 I/SA |
#37 | |
Banned
#38 |
When a written quality assurance policy is not specified there is a huge gray area for interpretation. The end result can be good parts that are rejected or bad parts that are accepted. Sound familiar? This is why written quality procedures are developed and issued to all companies and/ or people that have to conform to them.
#39 | |
Liked 2 Times in 2 Posts
#40 |
exactly why NHRA should not just change the spec with a stroke of the pen at Ford's behest
