Old 11-20-2009, 05:20 PM   #11
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Default Re: 1964 Chevelle 2 dr.or 4dr. wagon......
Originally Posted by W J View Post
Thanks everyone for that info....I was told that the only dif between the 327/250 motor and the 327/300 motor was the 300 version ran a Carter 4bbl vs. a 4GC Rochester on the 250 hp?? Any other differences in these 2 motors, heads or anything? Again, thank you. WJ
In 1965 the 300 HP had 1.95 intake valves vs 1.72 intake valves for the 250 HP.
Old 11-20-2009, 07:09 PM   #12
W J
Mr. Southerland, Are you refering to the same Holley-carbed 350hp/327 motor that was available on the '66 Nova cars? Available on the '65 Chevelles?? Hmmm....maybe I wasn't paying enough attention back then...Thanks. WJ
Was the 327/350hp combo available on the '65 Chevelle? I know a friend that had a '65 full-size Impala w/396/325hp 4sp combo, and heard of a few Z-16 /396 '65Chevelles being built, but thought that the first time those 327/350hp motors came around (other than in the earlier Stingray Corvettes) (I do remember that killer 327/365 '64 Corvette, as well...) was in the '66 Nova, no? When did the first 350 c.i. small blocks show--'67? Some mind-refreshing help on these 60's combos please, and pardon my ignorance... WJ
Old 11-20-2009, 07:23 PM   #13
james schaechter
Thumbs up Re: 1964 Chevelle 2 dr.or 4dr. wagon......
Bob Gipson had a 65 Chevelle that he ran with a 283 220 hp ,327 250 hp (this had double hump heads) and even put the 327 350 hp in it. The 350 hp is not nearly as good of a combo as the other 2. I did see a 65 Chevelle 396 in C/Stick in Florida. Pretty Cool, but not the easiest deal. Bob Gipson's Chevelle is now in Nova Scotia owned and raced by Jody Noble with a 327 250 hp stick combo. Great car and always raced with a stick.
James Schaechter 3163 STK
Old 11-20-2009, 07:40 PM   #14
W J
Thanks James, I did campaign a 283/220hp 4sp '64 Chevelle hdtp Malibu SS car back in the day...Actually, it was my very 1st "new" car. A friend had a '64 non-SS bench seat Malibu hdtp w/the 327/250hp 4sp Muncie combo. We both ran 3.70 rears....I never coud get by him at the track....sometimes close, but never got it done...later down the road, I installed 4.10's and started running better #'s than him....doesn't he go out and buy a '66 Malibu higher hp combo that I couldn't touch..... WJ
Old 11-20-2009, 08:20 PM   #15
Michael Kilduff
I am pretty sure the 350 SBC was first available in 1967 only in SS optioned camaros-295 hp factory rating. In 1968 the 350 was again offered in SS camaros and in Chevy IIs only. I would guess the 350 Chevy II was an SS option also rated at 295. Not sure when the 350 started showing up in trucks. In 1969 the 350 was available in just about everything at several HP ratings.
Michael Kilduff is offline   Reply With Quote
Old 11-21-2009, 08:58 AM   #16
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
W J -
Yes, the 350 hp 327 was available in all body styles as an option in the 1965 Chevelle. Also available in the Corvette. The '65 engine has a slight advantage of more compression (smaller combustion chamber). Same basic combination.
Old 11-21-2009, 12:59 PM   #17
W J
W J -
Thanks Dwight......WJ
Old 11-21-2009, 01:41 PM   #18
JRyan
Liked 112 Times in 31 Posts
Jerry, NHRA lists a '65 Chevelle 300 2s wagon, which was the 2-dr., with all engine options (including the 327-350) except the 396.
Dwight,
NHRA lists all the wagons in '65 as 2s. There were 3-seat wagons in '64, but no 3-seat wagons in '65 although one was run as a 3 seater for a couple of years in Division 5. But NHRA doesn't designate the 2 dr. wagon for '65 as they do for '64. Therefore, I don't believe it's actually a legal combo in NHRA. We used to have about ten '65's in town, and they were licensed as trucks and all owned by the Milwaukee Railroad (back then, Chicago Milwaukee St.Paul & Pacific). I really don't believe any were offered to the general public for sale in '65, and I was told that they were specially built for and delivered to the railroad.
In the early '70's a friend of mine bought one from the railroad and wanted to sell it to me. I inquired about racing it, and was told it was not in the Classification Manual, but I could change the front end to a '64 and run it. It may pass through Glendora today, but it didn't back then.
Jerry
Old 11-21-2009, 04:28 PM   #19
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
The 1965 Chevelle page in the NHRA classguide is unclear about the 300 station wagon. That should be cleared up shortly as I have sent an e-mail to Pat at the Glendora tech dept.
The 1965 Chevelle 300 station wagon only came as a 2dr model while the 300 Deluxe and Malibu were 4dr models. I know as I owned one of the '65 2dr wagons in the early 70's. Wish I still had it today as they are extremely rare with only 1668 units built.
Travis
(Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.)
Travis Miller is offline   Reply With Quote
Old 11-21-2009, 06:22 PM   #20
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 1964 Chevelle 2 dr.or 4dr. wagon......
So, both 250 and 300hp 327 versions of the Chevelle used the bigger valve cyl. heads in 1965? BTW, would you happen to know the dif in cfm ratings between that 300hp Carter and the 250hp 4GC?? Is it substantial or marginal? Thanks Jerry. WJ
In '64, the 327 250 hp.had the #520 or the 896 heads, and the Rochester 4GC with the small intake manifold. The 300 horse 327 had the same short block, cam, and had #461 heads and the 459 intake with the AFB. The carb looks almost identical to the rear carb on a 409.In '65, the 327 250 was equipped with the #461 heads. It had the same smll intake, and a 4GC with a Powerglide, and a WCFB if a stick.The 300/327 had the 459 intake and the AFB.The L-79 327/350 engine came out then, and was an option in the Chevelle and the Nova. It would have been possible to order out a '65 2 door 300 series wagon with the 327/350 engine and a 4 speed. How many of those do you think were made?
