Old 11-21-2009, 03:26 PM   #1
Jeremy K
Question 1986 Camaro Classification Question
Hi, I have a 1986 base model Camaro and I'm not sure which weight break to use. I looked at the NHRA Stock Car Classification and for the Stock factor with a 305/155/258 with Auto, it lists
CAMARO 101
Coupe 2 Dr 11.33
Coupe 2 Dr Berlinetta 12.06
Coupe 2 Dr W/700-R4 Auto 12.26
Coupe 2 Dr Z-28 12.22
Coupe 2 Dr IROC Z 12.40
It is not a Berlinetta, Z-28 or IROC Z, so that leaves Coupe 2 Dr and Coupe 2 Dr W/700-R4 Auto. The car came from the factory with a 700-R4, but a 3 speed would be used. So do I use 11.33 which is a natural G car, or use 12.26 which is a natural I car. Thanks.
Jeremy K is offline   Reply With Quote
Old 11-21-2009, 05:01 PM   #2
Liked 1,829 Times in 414 Posts
Default Re: 1986 Camaro Classification Question
You can use either.
Old 11-21-2009, 06:43 PM   #3
Jeremy K
Thanks for the reply. So if I can use both breaks, does this mean I could run the exact same combo in F, G, H, I & J by just changing the weight? (Probably not practical since the difference in min. weight is 516 lbs. between F and J for the 305/155) I just want to make sure I understand fully. Thanks again.
Old 11-21-2009, 07:33 PM   #4
Brian VP
Liked 8 Times in 1 Post
That is why they are such great cars.
Brian Van Poppel
Brian Van Poppel 1682 SS
Brian VP is offline   Reply With Quote
