Old 12-27-2009, 01:45 PM   #1
Adam Strang
Liked 96 Times in 23 Posts
Default Re: MSD ?'s
If your distributor is in good shape the Mallory Unilite conversion kit works great.Just make sure you get the surge protector to go along with it.
Adam Strang 1018 STK
Adam Strang is offline   Reply With Quote
Old 12-29-2009, 11:22 AM   #2
rod
Liked 20 Times in 15 Posts
Default Re: MSD ?'s
over the week-end, i did the following.
1. i phased the rotor, by sloting the vac. adv. mount, so i could advance the breaker plate. this allowed me to put the rotor exactly in line with the terminal. at both early and late mech. adv.*
2. i set the point gap at .012". i feel this will give the lowest 'movable' side acceleration speed and still give a good signal to the MSD.
3. i drilled several holes in the side of the dist. body [aluminuuuuuum] similar to the holes in the old cast iron bodies. i don't think enough oil gets into the bodies at high rpm, especially when i use the lifter cover. also i drilled a very small hole from the oil pressure groove to actually add oil pessure to the lower bush.
i still need to get an expert opinion on the 'E' rotor. there was a reason GM did that. i'm no electrician, so.....same for using/not using a condenser inside the chevy dist.
*i suppose that i could have bought an MSD rotor which has a movable tip, but i hot rodded it instead.
i have a sun dist. machine, which i really enjoy using. i can work with the weights and springs and get the adv. curve just where i want it. cool.
thanks rod the help and advice
rod is offline   Reply With Quote
