Old 01-19-2010, 02:34 PM   #31
Chuck Norton
Liked 85 Times in 19 Posts
Default Re: Who was the first 10 sec. stick Stocker and
I believe that the camshaft rules would have been roughly the same for a Stocker in 1971 as in 1978. Stock lift, duration, and overlap specs were enforced in both instances.
The piston in 1971 would have been required to have only the reliefs placed where they were needed for valve/piston clearance and they would have been no deeper than required for actual valve clearance. In 1978 the piston top would have been required to conform to the factory configuration.
I don't have a '71 Rulebook and I don't know what horsepower ratings were established in either instance. The Corvette appears to me to have been a '66 while Jim's car was a '67 Fairlane, I believe. The Corvette (if it was a '66) would have been a 427 with a single Holley. Jim's car might have been either a single or dual quad motor. It seems to me that he ran it both ways at various times but most commonly with a single carburetor.
Chuck Norton is offline   Reply With Quote
Old 01-19-2010, 03:38 PM   #32
bsa633
Banned
Thanks Chuck
see that it has a 7.49 factor at 425hp, and would have been exluded until AA come along..Just trying to establish why no 10 runs seem to be made between 71 and 78..
...7 inch tires and stock duration cam..thats impressive!
Cya in 3 weeks!
bsa633 is offline   Reply With Quote
Old 01-19-2010, 07:24 PM   #33
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Old stock vs new stock...........A cars minimum weight was the shipping weight back in the old days. No driver weight was accounted for. You were allowed 5 gals of gas and if you were light you could add a spare.
If you had a driver that was light, you had an edge.
Pistons......rings could be moved up and you could run any rings. Forgedtrues were pretty popular......
Valve springs had to check at stock pressures and we usually killed them if a shift was missed.
We ran GK and Lunati cams that had stock lift and duration....
7" tires and they were checked for width. As they grew you had to cut them or use a cheese grater.
M&H's were usually on stick cars and when Firestone came out with their "gumby" tires a lot of automatics used those......They were very soft and the hot rubbber from a new "trick" technique known as a stationary burnout.....burned the heck out of my ankles as I held the car.......
Rich Biebel
S/C 1479
Stock 147R
Old 01-19-2010, 10:32 PM   #34
Kent Hanley
The first iteration of Kent's 302 was in that car and ran 11.19@121 in 1982. Kent bought it in 1985 and he did much better with it than I did.[/QUOTE]
Dwight I think the east coast air was a contibuting factor to your motor running better in my car. :-)
Kent
Kent Hanley is offline   Reply With Quote
Old 01-19-2010, 11:48 PM   #35
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Originally Posted by Gary Waldo View Post
Dwight's correct, my Dad made the first 10 second Stock Eliminator run at Seattle on May 6, 1978. He went 10.95 at 124.82 to set the A/S national record.
Interestingly, it was exactly 23 years to the day (May 6, 2001) that Bobby DeArmond ran the first 9 second run at Mission.
Thanks for the facts Gary.. Sometimes tough for West Coasters to get any recognition. Also interesting that it took so long for a 1 second increase and now guys almost do it at will. Something stock must have gone out of stock. JMO!
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 01-20-2010, 01:43 AM   #36
Liked 5,113 Times in 1,948 Posts
With all due respect to Jim and family, it is factually incorrect to say he was the first Stock Eliminator car in the 10's.
He was the first 8 lb, 9 inch tire, modern configuration Stocker in the 10's.
Old 01-20-2010, 06:19 AM   #37
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Originally Posted by bsa633 View Post
Thanks Chuck
Cya in 3 weeks!
1971 would have been the last year for the 7 inch tire deal and aftermarket pistons, deep oil pans, etc. . The "NEW" stock eliminator began in 72. I think it was 74 or 75 brfore they were allowed headers again and real 9 inch slicks instead of those DOT slicks.
Old 01-20-2010, 06:22 AM   #38
X-TECH MAN
Banned
[QUOTE=Dinsdale;Also interesting that it took so long for a 1 second increase and now guys almost do it at will. Something stock must have gone out of stock. JMO![/QUOTE]
Then why all the bitching about losing 3 thenths off the index?
Old 01-20-2010, 08:30 AM   #39
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Originally Posted by Jeff Colvert View Post
Hey Dwight, If I remember correctly it was 1983 Green Valley you blasted doun the track with a 11.30 something for the record, only to give it up to S.E. & Kuntz when they made their run behind you a blistering 11.27. Little did you know that they had worked on the old CJ every night for a week getting it as perfect as it could be. I had also set my first SS/G record that weekend. LOL Are we having fun?
Jeff Colvert SS/G 4456
1983 10.51 @ na
2009 9.482 @ 140.53
Jeff, the problem with your memory is that the Camaro was the one that got torn down, SE didn't back up his run. So the Camaro got the record. That was also the race where I ran the 11.19@121 on Sunday morning after setting the record at 11.32@119 on Saturday. I think I may have bought fresh gas for the Camaro to get ready for that race.
Giving credit to SE and Jim, one of the outstanding performances I remember was at the winter series race in Lake Charles ('85 or '86) where they ran 10.80s in D. I believe it was the red car. I was in B there and could only run a few hundredths quicker.
We were all bad back then!!
Old 01-20-2010, 11:24 AM   #40
Jeff Colvert
Jeff Colvert's Avatar
Liked 3 Times in 2 Posts
Dwight:
Just talked to Verne. I needed him(with his computer memory) to confirm my memory of of that race. We set the record at 11.27 and backed it up with an 11.31, in fact I have the record certificate to prove it.
I remember that was a fun time to race because you had a bunch of guys in your class and all were friends and trying to out perform the other. Of all the things I miss about racing that is the thing I miss the most.
Verne doesn't remember the 11.19 run but I wouldn't argue with you since most days
now I can't remember what I had for lunch yesterday.
You LOOONG time Buddy;
S.E.
Jeff Colvert is offline   Reply With Quote
