Working on a buddies car, 84 camaro, putting a brake in it along with some other upgrades, I am not real familiar with the whole torque arm thing, I just noticed that it hooks to the tail shaft of the tranny, is there anything out there we can buy to move the arm off of the tranny? Again I haven't messed with these cars much at all so forgive me if I sound dumb. I would just think it would be hard on the tailshaft of the tranny. Suggestions please. Thanks
Eric Bowling |
Eric, you can contact a number of companies for this application. The one I bought was from S&W racecars out of Pa. The fit was not as good as one would hope for a bolt on kit but overall a really good system. There are other setups from Pete Z. and thirdgen.com. I hope this helps narrow your search, good luck!!!! Kevin
Liked 10 Times in 3 Posts
Eric, don't waste your time with the catalog stuff. I have broken it all with my 86 - 305 G/S.
Go with Pete Z - ATE Race Cars 315-483-6412. Talk to him about his anti-roll bar also. Rich Aman 1631 G/S
Rich Aman 1631 STK |
Liked 13 Times in 10 Posts
i would also agree with rich's suggestions i broke a sw torque arm with my k/sa 85 camaro pete z has the best stuff
Does anyone have pictures of the Pete Z kit for these cars that they can post here? Thanks!!!
Thanks for the input, Called Pete and he said he is way covered up and said that the BMR would be his next best choice, so that is the route we are taking. Thanks again!
Eric Bowling |
Eric, check your pm, Joe.
Liked 205 Times in 93 Posts
i see BMR has two types...factory length or the shorter unit. camaro/firebird stockers must have to use the factory length unit and they work great. which one to use for a bracket car?
Liked 216 Times in 77 Posts
I have the S&W stuff on my bracket car now but had a short one on it with the plate that bolts up into the driveshaft tunnel before. I really did not see much difference other than weight and maybe a sight difference in how high it carrries the front end. Just make sure you check the bolts holding it to the rear on a regular basis no matter which one you choose and a little locktite is not a bad idea either. As far as legality in stocker dont they just have to bolt up to the rear end the same way? I thought you could use the aftermarket arms that dont hook to the tailshaft as S&W advertises them as legal. Can anybody confirm this as my rulebook is not with me at the moment.
