Old 04-10-2010, 06:07 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Accepted intake manifold
Looking through the blueprint specs there are listings for intake manifolds for some SB Mopars. If there is no such listing given, is there some flexibility for the factory manifold used. Can manifolds be used from different years providing that they are still factory 2 or 4 bbl? Thanks
House of Darts is offline   Reply With Quote
Old 04-10-2010, 06:17 PM   #2
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Default Re: Accepted intake manifold
I too am VERY curious about this a combo I would like to consider someday well no manifold is mentioned, and I know the Japaneese market version is much more efficient....
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 04-10-2010, 08:46 PM   #3
SSDiv6
No. You have to contact NHRA. There are too many different engine specifications within the same engine family.
Old 04-10-2010, 08:49 PM   #4
SSDiv6
Japanese market version?
Old 04-11-2010, 12:01 AM   #5
GTX JOHN
.I am confused...are you talking about small block V8 or 4-6 cylinder mopar import stuff. All V8 stuff we run has multiple part #s and they do seem to flow and perform a little different for us. Thanks John Irving
Old 04-11-2010, 01:57 AM   #6
Yeah the one in my question is a "captive import" but its in the guides....
As in made in Japan, and branded here.....so the JDM (Japaneese Domestic Market) version of it is slightly different because of lack of emission controls then in Japan......
If I can actually FIND one, I had one once but now in 2 years I have found 2 both rusted beyond reason.
Old 04-11-2010, 02:00 AM   #7
I am pretty sure the original person meant an 8, I didnt mean to "hijack it" sorry....the one I am interested in is a 4 import
Old 04-11-2010, 03:18 PM   #8
House of Darts
I have a print out from NHRA that has manifold part#'s. There is no listing for the 273 4bbl. The 273 4bbl intake for the '65 has a different bolt pattern than the later years. The intakes runners are lower on the intake manifold than the superceded 302 head. The difference at the top of the port are significant and disturbs the gas/air flow from the intake to the head. I would like to use the late model intake from a 4 bbl 318 motor that the 302 was mated. Thanks
Old 04-11-2010, 05:20 PM   #9
Jeff Lee
Jeff Lee's Avatar
Is n't this the engine that received the Edelbrock LD4B as a superseded part?
Jeff Lee 7494 D/S '70 AMX
Old 04-11-2010, 05:34 PM   #10
House of Darts
If it is, you just made life a whole lot easier. I can not find this info.
