Old 07-05-2010, 06:13 PM   #1
Rick Leininger Jr.
Default Re: Why did nhra change the cam and valve spring rule in 1985?
No matter where you increase the opening and closing rates on the cam the valve MUST follow the ramp and the rate of opening or closing.
IF you use the ceramic lifters.
Rick Leininger Jr. is offline   Reply With Quote
Old 07-05-2010, 07:43 PM   #2
SSDiv6
Liked 1,582 Times in 582 Posts
Yep...in the past I have addressed the subject of valve train dynamics and camshaft lobes in the Tech section...there is a lot more on new camshaft designs that do not require the high spring pressures being used today...
