#151 |
Banned
Liked 235 Times in 110 Posts
Dont forget Wheelie bars, heavy duty valve springs, stainless steel valves, shubeck type lifters, fuel cells, weight bars and boxes, aftermarket rear springs, roll bars (cages), non-street pump gas, 2 steps, aftermarket disc brakes, alum aftermarket heads, replacement intake manifolds, solid motor mounts, acid dipped fenders-hoods-doors, aftermarket lite wt. wheels, screw in rocker studs, trans that never came behind the combos being used, elec. radiator fans, lite wt. swinging assemblys, after market rods, smaller rod journals, damn Im tired of typing this.
#152 |
Liked 16 Times in 11 Posts
Special runs must include a run of 50 units of an already accepted body style, need not be showroom available.
That is what it was changed to include ZL 1 cars and at that time they already knew the cj's were being built so its was dropped to 50 from 500 actual production cars. nhra did not even want a AA class at first, only after talk of new mustangs did they change their tune. If there had not been a AA class all the new cars would be in SS. Why is that so hard to understand, ford sealed the deal before the cars were done so they could also run Stock.
Bob Pagano A/SA |
#153 | |
Liked 444 Times in 145 Posts
Bruce Noland 1788 STK |
#154 | |
If a "crate motor" combo gets beat up too bad, then all the manufacturer has to do is change a few specs, re-submit it as a new combo (with a lower rating,of course) and we're back where we started. They can now play out this game for YEARS. That is, unless NHRA deals with it heads up, now. They won't. The title says it all.
#155 | |
Liked 1,836 Times in 417 Posts
Bob , the ZL-1 was back in the guide for 2-3 years before the new cars were brought in. In fact, the 50 cars built rule goes way back before that. And still, most of the new cars are not "produced", you get a pile of parts you assemble to make a race car, most of them will not start or move under their own power. In no way do they compare to the ZL-1, the L-88, the Hemi cars, or even the Boss 429.
Alan Roehrich 212A G/S |
#156 | |
You are attempting to compare parts purchased in order to make a race car out of a production car to a pile of parts sold by an OEM that doesn't even start and run, much less move under its own power or pass any sort of DMV requirement. Keep stretching and reaching, you'll never get there, but the exercise might help.
#157 | |
http://www.fordracingparts.com/musta...ner_Guide4.pdf |
#158 |
I didn't see any of the Windsor based engines in that user's guide. Not in the user's guide, or wrong year guide?
#159 |
#160 | |
Liked 19 Times in 7 Posts
ss/gt 93 t-bird Last edited by dwydendorf; 09-17-2010 at 06:43 PM. |
