Liked 3,219 Times in 980 Posts
Amen Brother. I will pass a good pit space close to folks I know if I see one of those B&S things chugging along. I have one of the quiet portables with extra length shore line so I can strategically place it for fumes to go away from others. If others aren't as considerate simply pack up your stuff and move if possible, CO poisoning is nasty stuff.
Same story here,our CO detector in the toter was going off all the time and was told to replace it as Jeff said these do go bad.
I did find out that these detectors are date coded so be sure you are getting a fairly NEW built one !!! Doug Wesler S/C 3703 S/G 3703 |
Most CO detectors sound off in codes that can be found in the directions. Keep in mind that any fuel fired appliances produce CO, stoves, refrigerators, heaters etc. The activation source may be coming from within your unit and the only way to be sure is to have someone take readings. If that is not available, the only safe thing to do is completely ventilate the unit and shut off all appliances until they can be tested.
