Old 03-25-2011, 12:42 AM   #1
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: Crate Engines in NHRA?
Originally Posted by Chad Rhodes View Post
well if a 170 IQ is half retarded, I'm ok with that. We get to race year round, y'all get to post on the internet for half the year. You also live in Canada, a country that could be taken over by our Boy Scouts before lunch time.
Ok you know what that has absolutely nothing to do with this post. Thats the most rediculous thing I have ever herd and you should be ashamed of yourself for even saying that. Our country has done nothing but help you in all your bogus war BS so cut the attitude and grow up.
At the end of the day we are arguing for nothing...this isnt going to be a vote as to who allows what in the NHRA....they are going to make the desision and thats going to be it. If they allow the crate engine into NHRA then it will be a good deal for us IHRA racers to come and race NHRA and travel and stimulate this crap box economy. More racers make small towns more money for business...any any increase in business will make everyone happy.
Sitting here and talking about the 674 intake with 448 heads and "ohh you have to run the 132 carb that has a lower casting from Hungry because it was .0004 faster to the 330ft mark" is rediculous. Your saying its just as cheap to run an NHRA combo...so I take my 454 block down to the machine shop for a $200 dollar a hole sleeve job...1600 in the block? Thats afordable? Ohh ya dart is making a new 396 block thats accepted in stock right...LOL Dart block in stock....and your worried about a crate engine.
And im sick and tirer of hearing "ohh your stupid for building a combo that can only run one Sanction" I chose to build a crate combination because it was the easiest way to run mid to low 11's with minimum cash outlay.
Pretty sure some of you guys have forgot that Stock Eliminator is an entry level sportsman class...the stands empty to eat hotdogs when we are in the lanes and the cameras are off.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 03-25-2011, 12:58 AM   #2
Chad Rhodes
first off your buddy made the disparaging comment about "you guys are half retarded", so go beat on him for lowering the bar.
Second off, the first thing I bolded is what class racing is all about. The second thing I bolded sounds like it came straight out of a bracket racer's mouth (not that there is anything wrong with that). About the third thing I bolded.........you have to look at NHRA national event sportsman class structure as two different ladders to the top. One one side, from bottom up, is super street, super gas, super comp, and top sportsman. These classes most often lead to the alcohol classes, pro mod, and the fuel classes (ala Shawn Langdon, the Force Girls, and others). The other side is stock, SS, and Comp. This side most often leads to Pro Stock at the top (stanfield, Brogdon, Kent, etc). Stock and SuperStreet would both be at the bottom rung on their respective sides, but the mindset is totally different on either side. Super Street is truly the entry level class here, and NHRA even states it. Class racing, on the other side is performance based and is about things like knowing the in's and out's of a motor, trans, etc and yes even things like that different carb base that's worth .004. If that's not what interests you, and you don't have the knack for it, maybe the other side of that "ladder" would be better for you.
I'm not trying to bash you, or suggest that you aren't cut out for class racing, but some of your own posts raise those questions. I'm also not saying that one side of the class structure is lesser than the other, or that they are mutually exclusive. There are lost of racers that excel at both. But they do require a different mentality and skill set. "going mid 11's for the least amount of money possible" doesn't sound like the class racer mentality. "going 1.00 under the index for the least amount possible" does, whether it be V/S, AF/S or A/SA
Chad Rhodes 2113 I/SA
Old 03-25-2011, 01:35 AM   #3
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
I had a long post all typed up and lost it,so I'll just condense it.If you two guys don't like using correct PN parts and doing weight and fuel check then just stay up where you bracket race and possibly association race where crates are allowed.The vast majority of us S/SS racers like doing stuff like having as close to factory parts and going through all the hoops required to race.Sure we're having problems with tech issues but we work as best we can.
Mr F Bomb,you sound like a real cocky SOB.Drive your what ever you drive down to Atco Raceway in NJ.There's a
few Jr dragster kids,if they were allowed to run regular
bracket cars,who would send you back to the frozen north with your F Bomb between your legs.
And Crate Camaro,"Our country has done nothing but help you in all your bogus war BS so cut the attitude and grow up."
Seems to me when the ***** hits the fan nobody gets on the telly with Ottawa.You know who they call.
And BTW the US kicked Canada's ***** already.Didn't you see it on South Park.And you can keep Terrence and Phillip.:>):>)
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-25-2011, 06:59 AM   #4
Hagen Gary
Liked 34 Times in 10 Posts
I don't know how you can argue with that. Good post Chad. Keep CM in IHRA. Lord knows we need the car count. I'm with ED on this too. The lack of parts in your area is no excuse for limiting yourself to one sanctioning body. I guess I just assumed that most CM cars are mostly bracket racers who run the IHRA races when they come in the area. I had no idea they actually wanted NHRA to change the rules for them. NHRA doesn't want older cars. Why would they give people a way to make them competitive again by adding whatever combination you want?
Hagen Gary is offline   Reply With Quote
Old 03-25-2011, 12:57 PM   #5
Chris1529
Liked 70 Times in 29 Posts
[QUOTE=Hagen Gary;248490] I guess I just assumed that most CM cars are mostly bracket racers who run the IHRA races when they come in the area.
I think that is a rediculous comment. I think if you look a little closer, you see there are many well built IHRA crate motor cars. There is alot of difference between the preparation for a nice class racing car than there is for a weekend bracket car. I don't agree with all the combinations of crate motors and rules that are out there, but if factored properly, there should be no problem running them as the basic premise is the same.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 03-25-2011, 01:18 PM   #6
My thoughts on this are pretty simple.
I like to look at a S/SS car and have an idea what engine combination might be in it
That's part of the allure and interest I have in those classes ...Always been that way.
Crate motors just don't do that for me. Too close to Bracket Two for a traditional guy like me. I feel the same way, to a lesser extent, about GT / Super Stock..... and definitely that way about Nascar.
As far as changing NHRA rules to accommodate your favorite car you drove back in high school...That's not the way it works in Stock Eliminator.
You build yourself a car that fits into the existing rules structure.
Seems simple enough to me...
How many you want?
http://phoenix.craigslist.org/wvl/cto/2272813283.html
http://phoenix.craigslist.org/wvl/cto/2250438196.html
http://phoenix.craigslist.org/evl/cto/2284359294.html
http://phoenix.craigslist.org/nph/cto/2212685293.html
Don't want to leave out the Blue Oval bunch:
Here you go. Runs P/SA or the bottom Pure Stock class in IHRA
http://inlandempire.craigslist.org/ctd/2260965401.html
Old 03-25-2011, 03:23 PM   #7
CrateCamaro
How many you want?
Ok I get it now...build a whole new combo and then its ok to run NHRA stock. Id rather not quote any of your posts because I have been in the internet war with you before and really its all verbal diarea as far as im concerned. Its ok to allow VW's into superstock, its ok for the new mustangs to have a blower and run at half of thier potential, its ok for the new chalenger to have an intake big enough for a top fuel car and apparently its now ok for a CRATE ENGINE 352 and 428 cube engine to run in the new mustang...????
1700 IHRA H/CM
1701 NHRA SS/?A
Old 03-25-2011, 03:44 PM   #8
Liked 1,953 Times in 439 Posts
See, here is what you don't seem to grasp. NO, it is NOT okay for any of those things to happen. Not at all. It has been FORCED upon us by NHRA, we never wanted it, we never said it was okay. So your argument that since that stuff is okay, then crate motors should be okay, doesn't hold water, not even a drop. NONE of it was okay with the vast majority of racers, it is just okay with NHRA, Ford, and Chrysler. So you expect us to say that, since NHRA has already screwed us, again, and screwed up the class, we will be just overjoyed to let them add something else that we don't want. That's a pretty ludicrous expectation. It's like telling a rape victim that, since she's already been raped, she should be okay with three or four more to step up and take their turn, too.
Let me spell it out for you, so you can grasp it. No, the things that you listed were NOT okay with the racers, and no, adding crate motors on top of all of the other things we did not want, is not okay.
Can you grasp it now?
In case you don't get it, the vast majority of NHRA class racers are sick of having things forced upon them, from higher fees for everything, to absurd schedules, reduced contingency payouts, stagnant purses, and the new underfactored cars. So don't expect them to want to have your crate motor program forced upon them., either. There's a reason car counts are down, and local grass roots combo programs are springing up. The racers are fed up.
Old 03-25-2011, 03:48 PM   #9
Hagen Gary
Yes, Its ok to run a VW in SS, but in case you havent been reading the message board. It isn't ok with the majority of people to allow Ford and Dodge to scheme the system by putting cars in the guide that were never produced. Same goes for your Crate. You built it knowing well and good that NHRA doesn't want you, now you want in. You keep making reference to old guys needing to give it up, but I bet I'm younger than you and I get that the basis of STOCK (Not bracket II) is that it was once a car that was available off the show room floor. I might not know what car came with what, but it sure intrest me to find out when I see it at the races. I walk right by a CM. I guess I didn't grow up thinking that everyone gets a trophy and rules should be changed to accommodate an outcast.
Old 03-25-2011, 03:53 PM   #10
1, Yes ,now you've got it.
2, If you DID want to get into an internet war with me, you'd have to read,write and spell past a 4th grade level.
3, VW's belong in Modified Eliminator, along with the rest of the hood scoop cars, if you want my opinion.
4, Blower, Turbos are fine with me if they came with the car in sufficient quantities and are rated properly.
If you think I'm in favor of Crate Motors of any kind in Stock, you've got the wrong guy.
