Old 04-19-2011, 12:59 AM   #1
HawkBrosMav
Liked 302 Times in 73 Posts
Default Re: CJ C-2 transmissions
have either of you actually seen one or are you just throwing useless info? any CJ guys out there no for sure?
Old 04-19-2011, 02:18 AM   #2
Look familiar?
Old 04-19-2011, 08:15 AM   #3
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
It is a PG with a Ford bell. I designed the first 3 proto type converters for them. Ford front mounting cover, from there back all GM.
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
Old 04-19-2011, 09:57 AM   #4
HawkBrosMav
Thanks guys I figure that's what they were but couldn't find a pic like the one Mark posted. since I already have one makes it a lot easier to consider this project.
Old 04-19-2011, 02:44 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Great information....
I went to my rulebook and in the Stock Eliminator, Drivetrain Section Transmissions, Automatic I found that "NHRA-accepted adapter plates permitted" and would possibly allow me to run a 904 Torqueflite behind my Pontiac engine.
I went to the NHRA website to look in the Accepted Products section for an adapter for a Pontiac Engine to 904 Torqueflite transmission. There isn't a section in the Accepted Products identified as "NHRA-accepted adapter plates"
Ther are no adapters listed so either all adapter plates are legal or no adapter plates are legal
I guess that it might be located in the East Coast on-line version of the NHRA rulebook.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 04-19-2011, 04:20 PM   #6
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Whatever rule book, just run a Pro trans and you will have your 904.
Bob Pagano A/SA
Old 04-19-2011, 04:45 PM   #7
Bob Mulry
Bob Mulry's Avatar
But the difference is that one of them is built in a stock 904 case and costs X amount of dollars and the other is a 904 built inside of a TH350 and it costs XXX dollars.
Neither is cheap but one them costs about 3 times as much as the other...for the same performance!!!
Bob
PS: I have no axe to grind with the Smith's...good people who build fast cars and transmissions...even raced against them in the same class 30 years ago.....
Bob Mulry 7516 STK
A & M Motorsports
