Old 05-20-2011, 03:56 PM   #11
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Re: worst red light debate, again!
Originally Posted by Neal Derochie View Post
To Bill Dedman and others, if this were to change one of the unintended consequences that could happen will alter qualifing vs. eliminations, just a scenario, take Fontana's elimination's ladder first round for instance.
Index Runs
#4 B/SA 11.25 10.53 -.713
#34 C/S 11.35 10.81 -.536
one would tend to believe that in most cases first round would look like this,
C/sa leaves first by .28 (all things being equal)
Now what could happen is after qualifing and only seconds before you run 1st round B/sa decides to put 10.99 on his window C/s had already put his original 10.81 and pulled into the water box thinking in most cases he is leaving first , so now you have switched (B/sa now leaves first by .18, just looking over other races this could be played out time and time again. Bill these are hypotheticals but it could and probably would happen with the new rule, i also understand that in cases this could happen already but generally B/sa is going to want to leave second .Bill can you see the mess this could cause which then would lead to another rule to prevent this. Unintended consequences. Bill just look at other races and see how many times this could play out. P.S. I think my numbers are right but if there is an error it is unintended. Bill now have you given some cars an advantage to pick and choose again?
Neal
What? Some of the "pro" Sportsman racers do this now, and have for years. It's called sandbagging. What's the problem again, and exactly how does it relate to Bill's debate here? Jim
