#16 |
Liked 10,820 Times in 2,249 Posts
Drive by wire is traction control!
If your foot is on the floor the throttle should be wide open. Yes the computer can adjust fuel and timing but should not be able to adjust throttle going down the track. Let the driver do all adjustments to the throttle position during the run. Solution is have a cable from accelerator pedal to throttle shaft and a throttle position sensor sending info to the computer. If the computer controls the throttle that is traction control. Drive by wire and the computer controlled throttle gives the racer the the unfair advantage of run tracing. Put a previous run in the computer tell it to trace and the run should be traceable to .002 of a second. Gps; I overheard a lady's voice in a new race car radio "Arrive at destination in 1320 feet, time of arival 9.582 seconds". As they say in the movies "Follow the money" Have you seen a Ford spin lately? Why are the governing bodies of this sport allowing the new cars to have such an unfair advantage in eliminations? |
