Old 06-24-2011, 02:08 PM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: 4 Speeds
Casey,
I've cut low gear to line up with cluster,I have found a 9310 low gear,Thank's Scotty D for the info.
Larry,
All Liberty has for Muncie or T-10 is a few parts and pieces in storage they have'nt had gear sets for them for a while as far as I know,they do still pro shift them but that is about it on T 10 or muncie.
Jeff,
You had me concerned there for a minute,I like watching you run. I owned 2 autos my first and last,without a stick it's no fun for me. Turn it loose on high side chip and try to rip shifter off every gear is best stress relief I know.
Mike Taylor 3601
Old 06-24-2011, 02:48 PM   #2
Casey Miles
Liked 508 Times in 92 Posts
Mike Taylor: There's a Liberty gear set for a Muncie on Ebay now. You are better off with a Super T-10 Liberty though. Once you have straightened out first gear, it should be OK. There is a place called S&K Speed shop on Long Island, the guy there is a guru on Super t-10s. He can make a fully sync trans. shift like butter. Use a soft clutch and it will live a long time.
Casey Miles
248H Stock?
Old 06-24-2011, 02:50 PM   #3
Jeff Colvert
Jeff Colvert's Avatar
Liked 3 Times in 2 Posts
Originally Posted by Mike Taylor 3601 View Post
Casey,
Larry,
Jeff,
Mike Taylor 3601
Yea Mike the stick does peg the ole Fun-O-Meter but its dishearting when your trans mfg. telles you there really nothing they can do for you, your car is too heavy and makes too much HP. Thats something I thought you could never have too much of.
Jeff Colvert SS/G,F,GT/B 4456
Jeff Colvert is offline   Reply With Quote
Old 06-26-2011, 02:49 PM   #4
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Jeff.. are you hurting a DR4-4? I thought they were pretty tough but also know guys who switched to a G-Force when the Jerico wouldn't hold up. G-Force clutchless is a different story and appears to be an expensive fuseable link.
I love my Jerico but lot's of good pieces available for a Toploader so I'd go that route if I had to. I'd rather run a lower powered combo than put in an auto.
Dale Posnick
Dinsdale is offline   Reply With Quote
