Old 07-03-2011, 03:08 PM   #4
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Default Re: Coil Location
Originally Posted by Dragsinger View Post
Dave, if you pass through the firewall be sure the coil wire fits loosely in the grommet. That is to say, grommet ID slightly larger than coil wire OD.
Also, what about the coil primary wires? Is the ignition controller already mounted inside the car? The primary wires need to be separated from the secondary wire.
The ignition box will be inside the car; (once I finish the install). I planned to run the coil primary wires through a separate port.
Thanks Larry.
Dave Turner
SS/GT #1153
