Liked 20 Times in 12 Posts
Do you guys have any ideas, suggestions or pictures of what bracket you built on your 12 bolt to hold the rpm pick up for a data logger? I would appreciate any pictures. This is going on a early model camaro. Thanks.
Robert |
Liked 13 Times in 7 Posts
Talk with the data logger mfg. I was told that someone makes a yoke that will work. The mfg. should be able to advise you.
Richard Grant 4988 STK |
That is what I have researched is the ring with the magnets can go on a certain M/W pinion yoke. But, I still have to mount the pick up on the housing some way. There is where I need some suggestions/help.
Thanks Robert |
On a early camaro the easiest and most economical way is to put the magnet ring on the slip yoke just behind the trans. You can then mount the transducer on a bracket made of flat steel from the trans mount. There is no problem with movement of slip yoke.
Liked 320 Times in 102 Posts
We just drilled the companion flange in 2 spots 180 degrees apart .250 diameter by the length of the magnet, epoxied them in place and fabricated a pickup mount out of angle iron that was drilled in 2 places and bolted to a rib on the housing..............
When we did our data logger (10 years ago) we couldn't use the commercially available magnet rings because of the distance between the rear of the companion flange and the face of the seal was too narrow..... It is out of the way and has worked fine for 10 years.............
[QUOTE=Bob Mulry;272883]We just drilled the companion flange in 2 spots 180 degrees apart .250 diameter by the length of the magnet, epoxied them in place and fabricated a pickup mount out of angle iron that was drilled in 2 places and bolted to a rib on the housing..............
QUOTE] Bob do you have a picture of your set up? This is what I was thinking of doing but I wanted to see what others are using. Thanks Robert |
Liked 308 Times in 103 Posts
you can fab bracket that attaches to ribs on housing that run below fill plug to hold pickup
M/W ring on pinion yoke for magnets works great . Mike Taylor 3601 |
Thank You Mike, that seems to be the simple way to do it. Bob suggested the same thing. Did you have to brace the angle piece of metal used to hold the pick up? Just curious.
Thanks |
used thin angle ,and never have took time to get working play back tach w/driveshaft rpm,always seems like I just get enough done to make it to a race or two a year and that seems to always involve a all nighter.
Mike Taylor 3601 |
