Old 08-30-2011, 08:01 PM   #1
JohnRoderick
JohnRoderick's Avatar
Liked 11 Times in 4 Posts
Default Strange Master Cylinder
Any have any experience installing a Strange master cylinder on a first generation Camaro? I am converting my '68 Camaro over to disc brakes and I ran into a little snag.
The bolt pattern is about 5/16'' off and the adapter kit they give you seems a little bogus. Anyone have an elegant solution with or without the adapter kit they give you. Any pictures would be greatly appreciated.
Many thanks!
JohnRoderick is offline   Reply With Quote
Old 08-30-2011, 08:51 PM   #2
Jim Grande
Liked 18 Times in 9 Posts
Default Re: Strange Master Cylinder
John, You don't need the adapter kit. Just slot the bolt holes outward til they fit.
Jim Grande is offline   Reply With Quote
Old 08-30-2011, 09:29 PM   #3
JohnRoderick
Jim,
Thanks for the reply. I did think about doing that, but I was concerned that I would cause the master cylinder flange to become too weak. Is it stron enough to remove roughly an 1/8'' on each side?
Old 08-30-2011, 11:04 PM   #4
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
I slotted mine open both sides... It's been fine.
Gary
L78 Nova is online now   Reply With Quote
Old 08-31-2011, 06:35 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Originally Posted by l78 nova View Post
i slotted mine open both sides... It's been fine.
Gary
x2
Push rod, and length is the tricky part.....
Old 08-31-2011, 07:53 AM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
Originally Posted by rallye bob View Post
x2
Agreed. I wound up using the Strange pushrod with the OEM retainer and clevis. I also replaced the OEM pin and clip with a 3/8" bolt and "double nuts" so that there basically no chance of it coming loose.
Jim Kaekel 3836 STK
Old 08-31-2011, 08:06 AM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Be sure to put some kind of stop on the pedal to prevent it from coming back up far enough to disengage the pushrod from the master cyl.
A few of the members on this board have had some wild rides because of this.
Old 08-31-2011, 09:55 AM   #8
Jim Kaekel
Tom is correct. I put a bolt/nut stop where the OEM brake switch was located.
Jim Kaekel 3836 STK
Old 09-02-2011, 03:13 PM   #9
JohnRoderick
Thanks all for the suggestions. Especially for the heads up on the push rod.
I filed out the master cylinder so the bolts would fit, then I used an after market clevis which is longer to make up for the short push rod.
