Liked 70 Times in 29 Posts
Alex, what is that 302 270/250 HP crate engine that some guys run? I don't remember it.
By the way, still debating about lifters. haven't done anything yet.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 Last edited by Chris1529; 12-10-2011 at 09:43 AM. Reason: spelling |
Chris, The 270/250 is the gt40p heads, flat top pistons with four valve notches, and the 498 lift cam. I thought the 215/240 engine was the same engine except the cam was the smaller I think 442 stock cam. Gary Peterson
Liked 369 Times in 127 Posts
I think this is the engine in question.
Basic production Mustang 5.0 longblock pulled from the assembly line and a couple of FRRP valve covers thrown on. Cam specs would be the same as NHRA Stock eliminator 87-93 5.0 engines I would imagine. ![]()
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Here are the other SBF crate engines from the 2002 catalog:
The 285/265/255hp engine has the gt-40 head, flat top pistons, 4 valve reliefs, 480 lift cam.
As I said earlier the 270/250 use the gp40p head (explorer head). The 215/240 engine is basically the explorer engine, Olin Welborn had this engine in his 68 Mustang in k,l,m crate motor when was running it in IHRA a few years ago.It also has the gt40p heads. The 95 Mustang that I ran in M/cm was the 270/250 engine. I tried the 285/265 when I first built the car but found that the gt40p head were a better head and at that time was worth the 15 hp difference over the gt40 head. I believe IHRA lower the hp to 255 last year. Gary Peterson |
Liked 4 Times in 3 Posts
Gary,
The 215 engine does not come with GT-40P heads. E7TE heads. It is based on a 92-93 motor with hyperutectic pistons and a .445 lift cam. Explorer engines had the GT-40P heads. Olin ran the 215 HP with the correct E7TE heads. He may have upgraded the motor to 270 specs at a later time. I have not spoken to him in a while. His car is a 65 Mustang not a 68. Chris, No problem, just let me know.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
Liked 393 Times in 153 Posts
Wow, ask and ye shall receive!
I've been running the spec's through a couple computor programs and the 215hp should run about -.400 under index...well as much as you can trust a computor. That was basically a stock 5.0 with a 750 and my mustang as it is. 4.86 gear/29.5X9/c4 with 3500 converter. With this combo my 4.86's seem too low and according to the computor 4.56's or even 4.11's seem quicker. Problem is, it shows the 750 better than a 650 and a single plane intake better than a dual plane. As we all know, a stock engine like that would benefit more from a dual plane intake and a smaller carb so I'm kind of skeptical. How did other's make out with this combo? Was it a slug or am I on the right path? And yes -.400 seems optimistic, that's why I'm doubtful it's that good out of the box. Thanks again, GB2 |
