Old 12-10-2011, 12:20 PM   #1
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
Default Re: lOOKING FOR SPEC'S 302/215@240
I think this is the engine in question.
Basic production Mustang 5.0 longblock pulled from the assembly line and a couple of FRRP valve covers thrown on.
Cam specs would be the same as NHRA Stock eliminator 87-93 5.0 engines I would imagine.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-10-2011, 12:28 PM   #2
ALMACK
ALMACK's Avatar
Here are the other SBF crate engines from the 2002 catalog:
I/PS '95 Mustang GT
Old 12-10-2011, 03:30 PM   #3
G PETERSON RACING
The 285/265/255hp engine has the gt-40 head, flat top pistons, 4 valve reliefs, 480 lift cam.
As I said earlier the 270/250 use the gp40p head (explorer head). The 215/240 engine is basically the explorer engine, Olin Welborn had this engine in his 68 Mustang in k,l,m crate motor when was running it in IHRA a few years ago.It also has the gt40p heads. The 95 Mustang that I ran in M/cm was the 270/250 engine. I tried the 285/265 when I first built the car but found that the gt40p head were a better head and at that time was worth the 15 hp difference over the gt40 head. I believe IHRA lower the hp to 255 last year. Gary Peterson
G PETERSON RACING is offline   Reply With Quote
Old 12-10-2011, 10:22 PM   #4
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Gary,
The 215 engine does not come with GT-40P heads.
E7TE heads.
It is based on a 92-93 motor with hyperutectic pistons and a .445 lift cam.
Explorer engines had the GT-40P heads.
Olin ran the 215 HP with the correct E7TE heads.
He may have upgraded the motor to 270 specs at a later time.
I have not spoken to him in a while.
His car is a 65 Mustang not a 68.
Chris,
No problem, just let me know.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 12-10-2011, 11:02 PM   #5
goinbroke2
Liked 393 Times in 153 Posts
Wow, ask and ye shall receive!
I've been running the spec's through a couple computor programs and the 215hp should run about -.400 under index...well as much as you can trust a computor. That was basically a stock 5.0 with a 750 and my mustang as it is. 4.86 gear/29.5X9/c4 with 3500 converter. With this combo my 4.86's seem too low and according to the computor 4.56's or even 4.11's seem quicker. Problem is, it shows the 750 better than a 650 and a single plane intake better than a dual plane. As we all know, a stock engine like that would benefit more from a dual plane intake and a smaller carb so I'm kind of skeptical.
How did other's make out with this combo? Was it a slug or am I on the right path? And yes -.400 seems optimistic, that's why I'm doubtful it's that good out of the box.
Thanks again,
GB2
Old 12-10-2011, 11:30 PM   #6
G PETERSON RACING
Alex I know he had the gt40p heads the last time I saw him run his car at Rockingham. He sat the record and had to tear down. I saw the engine apart and they were the gt40p. I guess I thought it was the 215 engine. I never did run that engine so really never looked at the spec's.
Goinbroke, with the 270/250 combo I had the 4.88's,c4, 750 carb, Victor Jr.,ATI4200 convertor and 30x9 Hooiser Radials. Could run 1.00+ under eight mile, 1.30 under quarter mile. Did a lot of testing with cam timing, carbs, and intakes, rear gears and this setup was the fastest. Good luck, Gary Peterson
Old 12-10-2011, 11:38 PM   #7
goinbroke2
Thanks Gary! Just as easy to pick up an explorer engine as a mustang engine to start with I suppose. I know I'll be nowhere near that as my car isn't "scienced out" like a real stocker. That's certainly encouraging though!
One other question then, were you running aftermarket rods/pistons or stock? (and how high were you twisting it)?
