#21 |
Liked 138 Times in 51 Posts
I've been using TTI 1 5/8"-1 3/4" step headers for many years. After the first couple of years of tuning, I added the TTI 3" X-pipe and Dynomax Ultraflow mufflers ending at the rear housing. After removing the extra 60-70 lbs the exhaust system added from elsewhere in the car and a little more tuning, the car was between .05 and .10 faster than the best I could get with their open header and collectors.
I may try the Dynomax bullet-style mufflers at a later date to save weight and have more room around the differential. But I don't know off hand how specific the IHRA Pure Stock rules are pertaining to mufflers for your application. |
#22 | |
Liked 6 Times in 5 Posts
We don't have any IHRA races close to here and I'd only be running the car in our local series, so I don't think they're gonna mind my 904. I'm trying to do this on the cheap (if that's even possible) and use as many parts as I already have, although it seems I now have to buy a set of small headers cuz I sold my old 1 5/8" ones last year. |
#23 | |
Banned
Liked 235 Times in 110 Posts
1969 Dodge Dart specs as follows: 63.3 Head C.C.'s deck .045 above block head gasket .035 Flat top piston with -5.45 cc valve relief Valve springs Intake & Exhaust 111 lbs on the seat and 240 lbs open pressures both have a damper Valve size: Intake is 2.080 diameter with a 3/8th stem Exhaust is 1.600 again with a 3/8th stem rocker arms are stamped steel with 1.5 ratio non adjustable (shimming required for rocker adjustment in ALL non adjustable rocker systems or adjustable push rods are allowed) intake manifold number 2531915 cast iron Carb #'s carter AVS # 4611 or 4612 Intake duration at .000 checking clearence is 336 degrees Exhaust is 348 degrees also at .000 checking clearence cam over lap is118 degrees Lift is .459 for the intake and .443 for the exhaust checked at the retainer. OEM oil pan required but internal mods and baffels allowed No +.013 crank stroke like on the regular stockers allowed The water pump must be crank driven as per OEM with OEM pullys and must have a fan attached to water pump pully. Originally the rear was OEM only but because of todays tire technology any MoPar rear is allowed to up grade for strength such as a Dana 60 to keep the parts INSIDE the housing and off the track. There is no wording on if a posi must be used or a spool is allowed. Your choice. Hope this helps. Terry Last edited by X-TECH MAN; 02-08-2012 at 09:22 PM. |
#24 |
Does IHRA allow a 2.08 intake valve in the 340?
#25 |
Banned
#26 |
Liked 51 Times in 25 Posts
My bracket 95 camaro has a stock motor/transmision but it has a roll bar is that allowed in pure stock.
#27 | |
#28 |
Liked 25 Times in 16 Posts
I think the current NHRA specs for a 1969 340 still apply to Pure Stock. The cam lift is higher on the exhaust. I think the service manual lists it as .429"/.444" or something like that, but Chrysler fed NHRA some enhanced numbers way back when.
HP Disp Deck Cl. Valve notch Int./Exh. Valve Cam lift 275 340 DP .045ab Flat w/n 5.45 cc 2020/1600 462/473 .035 Outer w Damp
Mopar 2 Ya! |
#29 |
Banned
Yes its 2.02......That was a typo. My falt, Sorry. I should have proof read it closer.
#30 |
Banned
