Liked 35 Times in 16 Posts
Don O Malley has a 58 corvette 2x4 set up for sale
greg SS/GT 3592 |
Liked 333 Times in 180 Posts
Dick--- look on Ebay currently several carb/manifolds combo also just carbs and just manifolds for sale plus correct air cleaners too---some with buy it now--Dick
Liked 3 Times in 1 Post
56 carbs and early 57 carbs are hard to find. They have the idle air screws near the secondary throttle shaft in the base plate. I have a set if you need casting numbers. I also have a 56 Chev .
Liked 32 Times in 19 Posts
Thanks for suggestions. I have found a couple of sets which are "rare priced". I will keep watching as I am not needing them today. The body work and chassis are nearing completion. Then as I can I will assemble the rest. Need to sell the Belvedere to create more cash flow for Delivery project.
Dick-- 1956 Chevy 2x4 manifolds #3728725 1st design and 2nd design #3731394 manifolds with 4 individual holes for carb barrels(1956 only and very very early 1957) versus #3739653 (1957-1961) which had 2 holes and one large figure 8 hole for each carb are available for anywhere from $200 to $700-$ 800 depending on condition and who you buy them from. Carbs(2419s & 2362s) are priced all over the place again condition is the pricing factor here...might do this piecemeal and get what you can afford now and as $$$$$ permits make a purchase of the rest of the parts as you go along---pay particular attention to bolt holes( manifold to head) on engines that have been decked the bolt holes will generally crack at 4 & 8 oclock positions ya hafta look very carefully---also look under the oil shield the tend to rot out in there - plus the heater hose nipples usually are rusted into the manifold very touchy repair to do properly----Comp
1956 chevy factory dual quad set up, complete carbs and intake, needs rebuilt, could use on vette? all correct numbers, $1,000. please call 847-877-6797. may take trade, no tex.
dick. this is on criags list chicago area greg meyer 3592 ss/gt |
