I'm rebuilding my front end on 1968 camaro and I'm about to cut moroso coils I have read a lot about having driver side 1/4 longer coil to off set driver weight is this the right thing to do?
Liked 93 Times in 52 Posts
No. Cut them equal. I have the lightest weight coil in my 68 sbc. I cannot remember how much we cut. It would not go in until we cut some off.
SAME LENGTH. My camaro is 3280 with me in it and I weigh 200. Car sits perfectly square. if it doesnt sit square then your leaf springs are worn out. Clark |
Liked 46 Times in 29 Posts
First off what he said, or your car can be twisted to, in then you will need to make more measurements like lower front control arm to frame by bumpers to look for sag, same w rear leafs.Measure all 4 corners of car before starting. Cut 1/2 coil at a time. do not fully tighten ball joints, and bounce it and let it settle a few days, unless its a mile in the air, then cut 1/2 coil off. they drop fast. sit in it then and take measurements w a helper there.
good luck, not much fun in spring work but patience pays off in end. Last edited by chris ok; 03-18-2012 at 02:27 PM. Reason: completing my ideas on how to do........ |
Liked 19 Times in 7 Posts
Moroso 47140...cut one coil for iron headed sbc combo
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
equal it is thanks for the help
Liked 165 Times in 51 Posts
How about a 69 Camaro with all iron 396?
