On the brake pedal? What works best. Brake light switch of some sort or a button mounted to brake pedal. I tried the brake light switch (factory) and it seemed really slow. I give it 15 or 20 hits then swapped to a trans brake button which seemed maybe .030 quicker. I seem to be consistant but I need anothe .020 to be in the game
Liked 91 Times in 51 Posts
If NHRA Stock, it must be mounted on the brake pedal.
Maybe something like this will
work for you Phil. Davehttp://classracer.com/classforum/attachment.php?attachmentid=11275&stc=1&d=13344566 73 |
I like the brake pressure switch. Tried light switch, but like the brake pressure better. Some use a gauge, others dont.
Put a simple toggle switch inline for on/off, so no issues in water box, etc. Also, some use a micro switch on the shifter so it only works in low gear. Others use a RPM window switch to do the same thing... dont want it on the top end! good luck Ken |
I have a b&m mushroom mounted to the pedal for today at tristate. I didnt care for the light switch. I will call the folks and check out the pressure switch. I did score a final in the bracket race last week so I feel I am going in the right direction.
I have the micro switch on the shifter so that the two step only works in low gear. I got 28 in fronts gonna take them off and put 24 on today and see how close I get. |
Liked 13 Times in 9 Posts
Definitely brake pressure switch. Many guys experience consistency issues with the standard "button on the pedal" deal. Folk will hook you up.
I put the B &M button on and went to rnd 5. My worst was a .018 and unfortunately I was perfect when I lost. I thought that wasnt to bad. Seemed like I had to stay after it tho.
da's some drivin' son! Good job!
Liked 2 Times in 2 Posts
Good drivin Phil!!! .018 as a worst is pretty good I think. LOL
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Liked 308 Times in 103 Posts
You keep on you're gonna get good LOL see ya some where soon.
Mike Taylor 3601 |
