Old 05-20-2012, 08:39 PM   #1
rod
Liked 20 Times in 15 Posts
Default Re: MS 1110H bearings ?
i looked at the pictures on e-bay. there are 12 pieces there. what are the copper shells for? they look like inserts for the rear main. right or wrong?
thanks for all the replies
rod in AZ
rod is offline   Reply With Quote
Old 05-20-2012, 10:50 PM   #2
JRyan
Liked 112 Times in 31 Posts
Rod,
Yes, the rear main uses a spacer on the MS1110-H.
Jerry
Old 05-20-2012, 11:41 PM   #3
FED 387
Liked 333 Times in 180 Posts
My experience issome of them are fully grooved depending on if you get "newer stock or older stock"---they only come in 3 sizes so if ya cut the crank more than .010 ya cant use em ----and yes the rear main uses a spacer---very expensive about $170-200 depending on who ya get em from----FED387
Old 05-31-2012, 07:40 PM   #4
firebird
I just got my clevite mains---is there any instruction on the rear main spacer--like loctite or? i would like your expertise please--thanks--spacers make me nervous
firebird is offline   Reply With Quote
Old 05-31-2012, 07:50 PM   #5
Liked 1,874 Times in 422 Posts
Never use Loctite on a bearing, it inhibits heat transfer, and slightly alters the fit.
