Liked 10 Times in 1 Post
A 1/4" of washers , it will never know the difference . Tack weld them together for ease of installation if you prefer.
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC |
Liked 239 Times in 114 Posts
Just make sure you don't space the pilot out of the crankshaft. That could cause a cracked flexplate , converter neck, or a vibration.
Use thick AN type washers, or make your own with a lathe.
As mentioned elsewhere, make certain that the pilot of the converter extends well into the bore on the back of the crank shaft.
Alan Roehrich 212A G/S |
Liked 333 Times in 180 Posts
try TE-CO Union Ohio--they make xtra thick hardened washers usually for use in machine shops for machine tool holding but never the less they make them--- probably from 1/4 in dia up to 1 1/2 inch several thicknesses
Liked 719 Times in 220 Posts
Ace Hardware has an assortment of thick washers. I bought some for just that purpose. Not having the converter in far enough can result in the front pump drive lugs breaking off. I learned that the hard way last year.
