Old 05-30-2012, 09:40 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default flex plate to converter spacers
I just know someone like Grainger, Fastenal or McMaster Carr stocks bulk spacers but time spent web checking has not found them.
I need 1/4" thick X 7/16" ID. Anyone have suggestions? Other sources?
Larry Woodfin 471W
Old 05-30-2012, 09:50 PM   #2
billy leber
Liked 10 Times in 1 Post
Default Re: flex plate to converter spacers
A 1/4" of washers , it will never know the difference . Tack weld them together for ease of installation if you prefer.
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC
billy leber is offline   Reply With Quote
Old 05-30-2012, 10:09 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Just make sure you don't space the pilot out of the crankshaft. That could cause a cracked flexplate , converter neck, or a vibration.
Old 05-30-2012, 10:18 PM   #4
Liked 1,874 Times in 422 Posts
Use thick AN type washers, or make your own with a lathe.
As mentioned elsewhere, make certain that the pilot of the converter extends well into the bore on the back of the crank shaft.
Old 05-30-2012, 10:34 PM   #5
FED 387
Liked 333 Times in 180 Posts
try TE-CO Union Ohio--they make xtra thick hardened washers usually for use in machine shops for machine tool holding but never the less they make them--- probably from 1/4 in dia up to 1 1/2 inch several thicknesses
Old 06-01-2012, 10:41 AM   #6
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: flex plate to converter spacers
Ace Hardware has an assortment of thick washers. I bought some for just that purpose. Not having the converter in far enough can result in the front pump drive lugs breaking off. I learned that the hard way last year.
