Old 07-04-2012, 07:47 PM   #29
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Default Re: Pure Stock-1995 Olds Achieva
Originally Posted by Robert Swartz View Post
Thanks Ed. Yes, I pulled the PCM fuse. Did as you said. Switched the key on for a short time, switched back off, replaced the fuse. Plugged in my scanner and it's clear of codes. Car still runs crappy, LOL! I clumbsily;sic removed the injector clips, being old and very brittle, a couple broke and I need to fish out the clips. Pulling #'s 1 & 4, the car still runs, pulling #'s 2 & 3, the car starts to die. Have I got a couple of dead or clogged injectors?
Bob
Could be coil pack for 1-4 is bad. By removing the injectors in the firing cylinders (2-3) and the motor tried to die you still don't know why 1-4 aren't firing. Since the two dead cyls are paired on the coil pack it almost seems more likely its that. If it was say 1-2 that wern't firing you could rule out coil packs
I think Autozone can test coil packs
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
