Old 12-30-2012, 09:39 PM   #1
Run to Rund
Liked 54 Times in 27 Posts
Default Re: 12 bolt ring and pinion set issues-
Motive bought Richmond a while ago. The Richmond equipment was very old and worn, so Motive is moving their production to Italy where Motive gears are made. Olds Richmond boxes will be old Richmond parts; new stuff will be like Motive. There are temporary supply disruptions.
Old 12-30-2012, 10:09 PM   #2
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
WHAT RATIO DO YOU need?
WE PROBABLY HAVE A MOTIVE GEAR SET IN STOCK.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 12-30-2012, 11:03 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
I have a good, used, Richmond high nickel 5.13 for 12 bolt
Larry Woodfin 471W
Old 12-30-2012, 11:11 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
I had the same problem a few months ago when I was looking for Richmond 12 bolt pro gears. Finally found a set at Mark Williams. Was told the same thing about Motive buying Richmond and they supposedly were to have new gear sets still under the Richmond name in the early new year.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 12-30-2012, 11:46 PM   #5
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: 12 bolt ring and pinion set issues-
5.57's. New only, street gears fine, no old used stuff.It's going into a rather heavy car.
Old 01-01-2013, 10:14 PM   #6
Mick Alley
We're having same problem w/ 5.57 pro gears, was told not available untill June.
Change them every season as part of normal maintenance, lucky we had one extra set of new in reserve, but need to restock. Jackie's car is a brute on that 12 bolt.
Mick Alley is offline   Reply With Quote
Old 01-01-2013, 11:26 PM   #7
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
I got my new ring & pinion from Strange Engineering, have you called them?
Link to there website: http://www.strangeengineering.net/index.html
