Old 06-30-2013, 05:28 PM   #1
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: BBM/Hemi stocker oil pan
Yep,I have a B-body car and a a-body with 440's.I can pull both pans by dropping the idler arm. Moroso has a 5 qt Hemi pan as does Milodon.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 07-03-2013, 02:24 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
What year is your B Body Chris?
2009 V/SA Record Holder
Old 07-03-2013, 03:30 PM   #3
Chris DeGidio
1970.
Nautilus Racing
Old 07-03-2013, 03:55 PM   #4
GTX JOHN
Liked 2,486 Times in 697 Posts
73 and 74 B Body is a Bear to find 6 quart that fits unless you move
engine back a inch or two. Anyone have any experience?
Old 07-04-2013, 01:41 AM   #5
Phillip marvetz
Originally Posted by Chris DeGidio View Post
1970.
Assuming that you have had it down the track what RPM are you turning it to?
Old 07-04-2013, 12:55 PM   #6
Chris DeGidio
68-7000 when we used to race it..why??
Nautilus Racing
Old 07-04-2013, 01:47 PM   #7
Phillip marvetz
Well because a Hemi needs to be spun over 8000rpm and I doubt a 5 quart pan has enough capacity. Also the 62-65 K member is different than the later model units which brings us back to the fact that Toms K member is going to have to be notched so the oil pan will fit therefore he should just get the larger capacity unit and done with it. This is assuming his car has the early K member still installed. It cost at least 20k to build one of these engines and I sure would not recommend he use a stock type 4-5 quart pan.
Tom, Please let us know what you end up using.
Old 07-04-2013, 06:31 PM   #8
Chris DeGidio
If it's a stock eliminator car,you can't run more capacity,and that's where I was going with this.
Nautilus Racing
