Liked 2 Times in 2 Posts
If it's a stock eliminator car,you can't run more capacity,and that's where I was going with this.
Nautilus Racing |
Oh, Wow. I have no response for that.
2009 V/SA Record Holder |
There's a whole lotta Stockers that can go 8,000+/- RPM and they are supposedly using the factory pans per the rule book. And I don't see in the rule book that you can notch the k-frame because why would you need to if you were running the stock pan, per the rules?
And if 5 quarts isn't enough, the rulebook does allow the use of an Accu-Sump. Or maybe 3 quarts in the pan, 1 quart or so in the filter and 3 quarts in the Accu-Sump... ![]()
Jeff Lee 7494 D/S '70 AMX |
#4 | |
Liked 10,721 Times in 2,232 Posts
Over fill the pan and use an accumulator to bring oil level down. My engine has never seen 8000 rpm, in fact I have a 9000 rpm tach. and the top third of it is never used.
Nautilus Racing |
