#11 |
You don't need one. Come up with some numbers on your own, post them on-line and eventually they will become fact. Happens all the time.
Jeff Lee 7494 D/S '70 AMX |
#12 |
What about if your motor lives in the 8500+ rpm range would it be better to have one? We both run 289 I run the trigger and he doesn't but both cars are very consistent.
#13 |
If you really have a race car where every .001 counts, and the rules allow a crank trigger, you should have one. The simple fact that a crank trigger is more stable, it has to be, should tell you there is something there.
Personally, I believe if someone that has never tried one, but denounces them, have no business saying you don't need one. For all they know, their car could be faster with one installed. But they'll never know... From my own experience, the two best things I can say about going from Stock to Superstock, aside from the extra 100 HP, was the shaft mounted T&D rockers over the OEM stamped steel rockers and the crank-triggered ignition. Both made the car more stable in their job and the result was a smoother running engine. And I probably have a better distributor system than most in Stock in areas that promote more accurate secondary ignition triggering than most out there. In my opinion, there is no way a crank-triggered ignition system CAN NOT be better than a distributor triggered system. You throw a timing chain in there, cam twist and or flex, meshing of two gears, oil pump issues, valve-train issues (spring pressures, harmonics, etc.), etc.,....I'm all ears if you think you can convince me the crank-trigger ignition is "maybe as good but not better" than a distributor triggered ignition. My new ignition is for Stock and I'll be using an ICE Ignition which is a hall-effect system. I don't hear much about that but I believe it is a better system than the monkey see, monkey do MSD system. But I could be wrong. But I will test both systems on the dyno. Then I will know, not guess.
#14 |
Liked 36 Times in 26 Posts
I always ran a billet distributor for years with a curve in the distributor, and I finally went to the crank trigger and programmable ignition before I started this season. Had to have some machine work on my crank mandrel to fit the wheel on the front of the balancer, and also upgraded the ignition boxes. I picked up a lot. Too much in fact. I run the car in super gas and I don't run a throttle control, I change the shift points for the five speed, using a automated programmable shifter. It was too fast for what I was trying to do, and then I retarded the timing to slow it down, and that worked ok, until, the weather changed big time. Still trying to come up with a programmable curve, so I can control things the way I want. Got close this last two weekends, but then started spinning the tires when it got real hot. Crank triggers are a little bit more expensive, but you can do a lot more with them. I will never go back to a distributor controlled ignition, unless it is on the street car that I am trying to get back to.
#15 |
Liked 759 Times in 379 Posts
Unless the op is racing Pro Stock, Pro Mod, Comp Eliminator or turning 9000 RPM in a super stocker looking for that last .01, a crank trigger is worth NOTHING on the time slip compared to a properly functioning locked out billet distributor.
#16 |
You don't know what your talking about. You read it or heard it somewhere and now it is gospel to you. And I'm sure about now you'll tell us you tried one and it didn't help.
#17 |
Jeff, he is a bracket racer that doesn't even build his own engines, but he knows more about all this stuff than we do. He can't run faster than the shoe polish number if he has a heads up. No need to chase hundredths. Just change the shoe polish. He knows just about everything, except how to find the et bracket section here.
Ed Wright 4156 SS/JA |
#18 |
Liked 91 Times in 29 Posts
I am surprised he has not commented on Mexjoe's broken crankshaft ordeal.
#19 | ||
you really think you're special. Newsflash, it's the year 2013 not 1963!
Over the next 4 months, Tilburg's, Gulius's, Watters's, Patterson's, Bischoff's and other's engine shops phones will be ringing off the wall and their shops full of the engines for and from the biggest and winingest names in class racing just as will Sunset's, Reher Morrison's, Par's, Shafiroff's, Schimdt's and others with their shops full of and building engines for the who's who of super comp, gas, street and bracket racing and you think you're special cause your "build" your own. Too ****** funny! ![]() The truth is YOU buy your engine parts just like I do and the vast majority of class and bracket racers do, you pay a machine shop to do your machine work just like I do and the vast majority of class and bracket racers do... Quote:
![]() Further, last I checked when reading National Dragster, the NHRA doesn't award Wins, Wally's or $$ for those who's claim to fame is they built their engine! Fletcher along with the biggest names in NHRA Sportsman racing don't build their own engines but somehow, he just managed to win his 84th and 85th Wally. ![]() Oh and btw, the vast majority of class and serious bracket racers don't build their cars, carbs, transmissions, converters and headers and neither do you! ![]() What I KNOW is what works on the track, showing on the time slip and what just lightens your wallet! Last edited by 1320racer; 09-02-2013 at 12:37 PM. |
#20 |
Liked 30 Times in 17 Posts
Two Eds, one brain.
