Old 11-03-2013, 08:55 PM   #14
Jody Lang
Liked 89 Times in 28 Posts
Default Re: Disc Brake Conversion
Originally Posted by Mark Ruset View Post
Thanks for your reply Jody, can you elaborate on your comment on what does it take to hold a car on the starting line? My only issues is the starting line, if I get up on the convertor much more than 2200 the car wants to push through the beams. the car on the top end stops well.
2200 is very low for drums to say the least. Discs will be a safer system (no pulling to one side). You still should be able to stall a drum setup higher than a disc.
Jody Lang is offline   Reply With Quote
