Old 11-12-2013, 04:23 PM   #1
Chuck Garey
Liked 10 Times in 7 Posts
Question Battery Recomendations
Ok guys batteries died in car last race of the year, looking to replace in spring. Any recommendations of brand, type? Dual batteries here front/back
Chuck Garey is offline   Reply With Quote
Old 11-12-2013, 04:47 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Battery Recomendations
If you want something fairly lightweight, I've used Braille B3121 batteries (21 lbs.) with good luck. I try to swap batteries every 3-4 yrs.
Jim Kaekel 3836 STK
Old 11-12-2013, 05:19 PM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
I've used the oddesy batteries with never an issue. Finally replaced it this year only because it was 5 years old. Never let me down.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 11-12-2013, 06:54 PM   #4
Greg Hill
Liked 279 Times in 68 Posts
I also have had good luck with the Odyssey batteries. We use two of the 925's.
Greg Hill 4171 STK
Old 11-12-2013, 07:36 PM   #5
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Optima yellow top any good for drag racing ? I saw one in the Fletch's stocker wagon @ Indy.
Tim H is online now   Reply With Quote
Old 11-12-2013, 07:46 PM   #6
JimL
Optima yellow tops work great since they are a deep cycle battery. However, you also need a charger made for this type of battery. Sears makes one and I think Optima also has one.
JimL is offline   Reply With Quote
Old 11-12-2013, 07:47 PM   #7
theman440
theman440's Avatar
Liked 24 Times in 13 Posts
Optima Red tops is what I use - never let me down.
Jeff Dudgeon
'66 Coronet #10771 - bracket puke
"the Flying Brick"
theman440 is offline   Reply With Quote
Old 11-12-2013, 07:58 PM   #8
Mark Ugrich
Liked 71 Times in 38 Posts
I've run an Optima yellow top for years. One of the best batteries I've tried, albeit somewhat heavy. It may have been wrong, but I always used a standard charger on it. Never had a problem.
Old 11-12-2013, 08:08 PM   #9
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Battery Recomendations
Chuck, You have a PM...........
Dave Ribeiro 1033 STK
Old 11-12-2013, 11:16 PM   #10
Tim H
Tim H's Avatar
Likely referring to a slow charge on 2 amp or similar ?
