Old 09-24-2007, 09:31 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question Trailer Floor.....Mill Finish Aluminum Cleaning
Anyone got the "trick lick" on cleaning trailer floors---Mill Finish Aluminum Treadplate or Extruded----Black marks accumulate on that too but it seems to be very tricky to spot clean without leaving a noticable black "smudge"...any suggestions ????
Rusty Davenport is offline   Reply With Quote
Old 09-24-2007, 10:25 AM   #2
RIBEIRO RACING
Guest
Posts: n/a
Default Re: Trailer Floor.....Mill Finish Aluminum Cleaning
Yah,Rusty
Try the RV-455 you have you will be surprised, then you will have to buy MORE....Spray it on and give it 20-25 seconds and wipe and rinse and see what happens...Then call me...
Dave...1033/stock
Old 09-24-2007, 01:04 PM   #3
John Musial
Liked 51 Times in 3 Posts
Thumbs up Re: Trailer Floor.....Mill Finish Aluminum Cleaning
I just did mine. Get yourself an orbital floor polisher and put the most abrasive pad they have on it. (looks like black Scotch Bright). I used 409 cleaner but Iam sure Simple Green or some other cleaner/de-greaser will work. Run that bad boy on the whole trailer floor, and it looks like new.
John Musial is online now   Reply With Quote
Old 09-24-2007, 02:59 PM   #4
Dick Butler
Liked 32 Times in 19 Posts
I'd go light on the abrasive disc using one of the milder ones. Simple green and wet floor work great. You get a rythm and you can make a nice pattern without gouging the aluminum. THEN when you rinse it out and it is dry and you are satisfied .... Take some Liquid floor wax ( MOP and GLOW)
and spread it on with a rag by hand all over this helps slow the oxidation and marks.
Good luck it takes time and energy but it DOES look like new...
Dick
Old 09-24-2007, 03:03 PM   #5
SSDiv6
Liked 1,604 Times in 583 Posts
Be caraeful with the use of abrasives on aluminum unless your plan to apply a primer or epoxy paint. The abrasive will remove the annealing and then you will have a corrosion issue with the aluminum. Use the RV-455 and you will be safer.
Old 09-25-2007, 10:24 PM   #6
Lynnmsp
Dave will you be at Columbus?Used RV455 today and was very surpised.It has simple green beat ten times over.I will need more product.I have an other person coming tomorrow to get a sample for a test on his trailer.I am sure he will want a gallon also.
Lynnmsp is offline   Reply With Quote
Old 09-25-2007, 11:34 PM   #7
RIBEIRO RACING
Guest
Posts: n/a
Wink Re: Trailer Floor.....Mill Finish Aluminum Cleaning
Lynn,
No, I will at Budds Creek, Md (MIR) IHRA Nats this week..Good Luck at Columbus...Also,glad you like the product and remember it is the Dam Best Blackstreak Remover out there...Send me an e-mail and I will take care of your needs.... thanks, Dave...1033/stock (350 ci)
